Diff Plug Removal - Need tool Help!
Old Apr 18, 2006 | 03:55 PM
turbo78vair's Avatar
turbo78vair
Default Diff Plug Removal - Need tool Help!
Posted earlier, but did get any response so will rephase my needs. I want to change the rear end gear lube and additive. Would like your input as to what tool you use to remove/install the 5/8 in square head plug. As many of you are aware, can see the plug, touch the plug, but tool arc of swing is minimal. 5/8 inch open end obviously fits, but can't turn it enough to get another grip.
What tool do you use on this plug?
Gary C
Old Apr 18, 2006 | 04:53 PM
SIXFOOTER's Avatar
SIXFOOTER
dogbone wrench
Old Apr 18, 2006 | 05:03 PM
pws69's Avatar
pws69
Gary C
Try a 1/2" extension (obviously, if it's a female plug)...
Old Apr 18, 2006 | 05:12 PM
vairxpert's Avatar
vairxpert
Just changed mine 3 days ago. It's tight but I managed to remove it with a plain old open end wrench. There's a bit more room if you get the wrench positioned towards the front of the car.
Don't forget your posi-traction additive!
Old Apr 18, 2006 | 07:29 PM
C3 Stroker's Avatar
C3 Stroker
I just jack the car up, remove the rt. rear tire (give yourself some room), attach a long extension to the socket and an 18" breaker bar (persuader), and give it a twist...........(this is an extreme measure, but it beats struggling and contorting).
Old Apr 18, 2006 | 08:41 PM
gator79's Avatar
gator79
did mine with a crescent wrench (metric)
Old Apr 18, 2006 | 09:03 PM
7t5's Avatar
7t5
St. Jude Donor '14
I too pulled the spare and carrier. Easy job with these removed. The guy at the oil change shop gave up so I went home and removed the crap. It immediately cleared up the groaning in my rear end when I changed the fluid. Also, i later read that a 12 pt. socket will fit, but I cannot remember what size.
Old Apr 18, 2006 | 10:15 PM
vairxpert's Avatar
vairxpert
How much fluid did you guys remove/put back in? My Haynes manual doesn't mention the capacity and AutoZone's computer said 4 quarts. I used a drill mounted pump and was able to remove about 2 quarts. Sound right?
Old Apr 18, 2006 | 10:58 PM
turbo78vair
Thanks to all for your valuable input. I will probably give it a try tomorrow. Sorry for double post - didn't think anyone had responded to my initial thread.
Take care
Gary C - '78 Pace Car
Old Apr 18, 2006 | 11:34 PM
C3nMe's Avatar
C3nMe
However, mine was an expensive left-handed metric crescent wrench -- at least until I could turn the plug by hand.
Brian.
C3nMe
Old Apr 18, 2006 | 11:43 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Takes just under 2 qts.
I use an EIGHT pt. 5/8" half in. drive socket, 10" extension and my longest handle ratchet. No problems with access at all. The plug can be pretty tight.
Mike
Old Apr 18, 2006 | 11:44 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Pick up a 5/8" 8 point - 3/8" drive socket.
Old Apr 19, 2006 | 10:50 PM
turbo78vair
Worked on Vette this afternoon. Put rear up on ramps, dropped the space as several had suggested, removed lower clamshell, used crescent to easily remove the diff plug.
Mission accomplished - lube changed(with additive) - road tested all ok.
Take care
Old Apr 20, 2006 | 11:57 AM
kdf1986's Avatar
kdf1986
Gary,
What was the turning point in this project. Was it removing the spare tire to get enough access room for the plug, or was it getting the right tool to fit the square opening?
From my experience it was taking the long way, and removing the spare tire carrier which made the whole job easier.
kdf
Old Apr 20, 2006 | 04:18 PM
turbo78vair
kdf - good afternoon from Southern IN. I'd spent quite abit of time under the Vette pondering how to get the plug out. I have a pretty decent collection of tools, but fact that plug was rounded some help in my attempts.
The time spent to drop the spare, pull it out and remove the lower clamshell was well worth it as now could easily get at the diff plug with my Crescent (metric). It also made the job of changing the fluid alot easier.
Had I been on the clock attempting to meet flat rate or SRT or whatever, would not have been wanting to drop the spare, but I'm not on the clock. Well, maybe my retirement clock!
Again, thanks to all for the suggestions.
Hope you are having a great day. Took some shots of the pace car sitting amidst some of the beautiful spring flowers at our place yesterday. Can't wait to get them back tomorrow - I know - the old fashioned way.
Regards
Gary C - '78 Pace car
Old Apr 20, 2006 | 04:25 PM
Allen_396's Avatar
Allen_396
kdf - good afternoon from Southern IN. Gary C - '78 Pace car
Where in southern Indiana are you?
Allen (also in southern Indiana)
Old Apr 20, 2006 | 05:41 PM
turbo78vair
We're in the Franklin area. Nice down your way. Would like to cruise down there along the river. We were down that way last fall. Went to Clifty Park, downtown Madison to check out a kids toy store and across the river to KY for a short run down the renewed highway to the east.
Take care
To Diff Plug Removal - Need tool Help!
