Headlight conversion
Old Apr 22, 2006 | 10:07 PM
JustForFun's Avatar
JustForFun
Default Headlight conversion
Im thinking about swapping my headlights over to the daytona style lamps with the covers. Anyone else have these? comments on em?
any suggestions on where to get em? Ecklers seems WAYYY overpriced on them
Old Apr 22, 2006 | 10:13 PM
LittleJake's Avatar
LittleJake
comments on em?
I wouldnt do it, I think most that do end up swapping them back after they come to their senses.
Good luck either way!
Old Apr 22, 2006 | 10:37 PM
copter's Avatar
copter
Isn't there a way to convert to electric.Seems like I heard of some who use 4th gen firebird stuff.Any truth to this?
Old Apr 22, 2006 | 10:38 PM
JustForFun's Avatar
JustForFun
there is some kits out there to do that. since im converting to a convertible, i figured ide throw this in there
Old Apr 22, 2006 | 11:22 PM
SIXFOOTER's Avatar
SIXFOOTER
no real good reason to convert to electric. Think about it, the vac operated one has been workin on your car for how long? 25 years? Slap on some new hoses, cleanup the buckets and your good for another 25 years. Even on a humpy cam low vac engine, they will come up slow but lock in place when they get there.
Old Apr 22, 2006 | 11:41 PM
onaqwst's Avatar
onaqwst
or do what i do...... just open them up manually and close them the next day once the sun is out..... the trick is to find that lockin arm to push.....
b
Old Apr 23, 2006 | 01:58 AM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Tired of DIM LIGHTS?
Put these lights in - They convert the 4 bulbs to 4 special cases. In these cases you can put standard hallogen or xenon type bulbs, the same bulbs that fit in modern cars. You can put xtreeme white, blue, etc.
I put 65 watt low beams and 105 watt high beams in my Vette. I also put in a relay system, as the stock wiring probably can't supply sufficient juice to the new bulbs. Simply put, I installed a relay on the low beam wire, and a relay on the high beam wire. When you turn on the headlights, the voltage from that triggers each relay, which has a bigger wire with fusable link straight to the battery. I only use the stock wiring to tell the relays to turn on the lights, which use the new bigger wire to light the light.
The old wiring system in the Vette doesn't produce enough voltage or wattage to light the new lights, and another consideration is you might overheat the old wires if you use them straight to the new bulbs. That could cause a fire or melted wires.
Now I got headlights. Damn do I got light. Just finished all this tonight.
Check out the Hella website, and see what ya think.
Thanks to all the other guys in this forum to come up with this collective headlamp solution.
http://www.hella.com/produktion/Hell...ision_Plus.jsp
Old Apr 23, 2006 | 02:15 AM
TonySinclair's Avatar
TonySinclair
f. gregg racing has 'em:
http://www.fgreggracing.com/index.as...teID=101415373
Old Apr 23, 2006 | 07:14 AM
1969Vette383's Avatar
1969Vette383
Didn't I read somewhere on the forum that someone installed aircraft landing lights as their high beams? Talk about some extra light, Day-um! I'm surprised their local airport tower doesn't try to contact them and get them onto runway two-five-left!
Old Apr 23, 2006 | 08:08 AM
comp's Avatar
comp
Old Apr 23, 2006 | 09:32 AM
snake321's Avatar
snake321
they were on my car when I got it. Besides the fact that they don't throw light well and look stupid, people constantly keep telling you to put your lights up. I got pulled over and got in an argument with a cop who was telling me to put my lights up.
Old Apr 23, 2006 | 12:12 PM
lvrpool32's Avatar
lvrpool32
I have 'em, love 'em and will not be changing back to pop ups.
They are lighter, I put H4's in there so brighter, and I got rid of the damn vacuum system.
If fixed lights where good enough for the original corvettes (and the latest) and good enough for the L88 race cars...then they are good enough for me.
Nick
Old May 2, 2006 | 11:18 PM
Fireslayer26's Avatar
Fireslayer26
Default lvrpool32
lvrpool32, what kind of hardware did you use to attach the covers to the buckets?
Old May 2, 2006 | 11:31 PM
Jclgodale3's Avatar
Jclgodale3
Nick
Although I did repaint the original doors and bezels with the new color in case I do want to go back at some point.
Old May 3, 2006 | 12:21 AM
TonySinclair
Originally Posted by Jclgodale3
That's a beaut...
Old May 3, 2006 | 12:37 AM
Jclgodale3's Avatar
Jclgodale3
Thanks....there's alot of inspiration here.
Old May 3, 2006 | 02:59 AM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
yOUR VETTE LOOKS GREAT....
To Headlight conversion
Old May 3, 2006 | 10:55 AM
Captain America 79's Avatar
Captain America 79
Cruising
snake321 are they for sale if you still have them?
Old May 3, 2006 | 10:57 AM
Captain America 79
Cruising
Are they for sale if you still have them call me at 630-772-0554
Strat Matsas
Old May 3, 2006 | 04:57 PM
Star79's Avatar
Star79
Originally Posted by TonySinclair
check out the C3 for sale section, redvetracr has a complete set for 400 bucks.
