operating temp question
Old Apr 27, 2006 | 12:02 PM
BarryK's Avatar
BarryK
Paul, yes, I understand. I wasn't concerned about overheating at those temps, just wanted to make sure it was in the "normal" range.
I guess i'm too used to my '65 so it's disconcerting to look over at the dash on ther '78 and see 210*.
I'm thinking to MAYBE swap out the 195 t-stat to a 180.
I sure don't need the higher temp t-stat for heat in the car and as long as the temps are still high enough for proper emission function it MAY allow the temps to run a little lower.
Of course, even with a lower temp t-stat it may not make difference if these are the temps the car wants to be at.
Old Apr 27, 2006 | 12:06 PM
big_G's Avatar
big_G
I bet you have an aluminum radiator in the C-2, and a copper/brass one on the C- 3. That would account for a difference, IMO.
Old Apr 27, 2006 | 12:19 PM
BarryK's Avatar
BarryK
good point I didn't think about and yes, that's true. The C2 has a DeWitts Aluminum Restoration radiator and the C3 is the original Brass/Copper unit.
I forgot to take that into accout also.
Old Apr 27, 2006 | 01:39 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Barry, you probably know the gauge isn't very reader friendly, few numbers. With that said, at idle in the barn my 79s seem to be about 190-200. Haven't really needed to pay a lot of attention to the gauges as no trouble in that department ever.
When I drove my white 79 home last year from Rhode Island, 1000 miles, pretty much straight through, I did pay attention to all the gauges. Temp stayed about 200-210(just before the 220 no on the gauge) all the way, never budged.
My 79s also have the aux electric fans. I think they turn on at 240 and off at 200. I have never seen those fans run on either 79.
Both still have 195 stats.
Mike
Old Apr 27, 2006 | 03:24 PM
BarryK's Avatar
BarryK
thanks Mike
that just gives me additional confirmation that my car seems to be in the normal operating temp range and that's all i needed to know.
Like I mentioned before, since it runs at a higher temp than my '65 I just wanted to make certain that where it was running temp wise was normal
Old Apr 27, 2006 | 03:48 PM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
My 70 454 runs 180-200 all day long.
Old Apr 27, 2006 | 04:07 PM
snake321's Avatar
snake321
Mike
I took off my flex fan and took out the air conditioner radiator and am gonna try just the aux fan.
