Wrong gasket????
Old Apr 26, 2006 | 09:37 PM
1974slcvette's Avatar
1974slcvette
Default Wrong gasket????
I recently rebuilt my 1974 Quadrajet, and have been working on timing, idle, etc. I have discovered that I am getting little or no vacuum at the port in the side of the carb pictured below (Vacuum gauge reads 1 in/Hg). This port is attached to the Engine Solenoid, which in turn is attached to the Vacuum Advance on my distributor. Did I possibly install the wrong Throttle Body gasket? Thanks for any help, suggestions...
Old Apr 27, 2006 | 11:27 AM
1974slcvette
Nobody???????
Old Apr 27, 2006 | 05:57 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Well, I can't answer your question directly, but I can say that from decades of rebuilding carburetors, including One barrel sidedrafts, AFB's, WCFB's, Rochesters, etc., I always compare the "new" gaskets with the old ones I took out.
On MANY occasions, the carb kits are for multiple applications, and thus have different gaskets, which JUST MIGHT be missing an air bleed hole, etc. Chuck
Old Apr 27, 2006 | 07:02 PM
E_Tar's Avatar
E_Tar
Originally Posted by 1974slcvette
......This port is attached to the Engine Solenoid, which in turn is attached to the Vacuum Advance on my distributor. ....
The knee bones connected to the shin bone, the shin bones connected to the ankle bone, the ankle bone connected to the.....
No, really, I would buy an assembly manual (costs $30).. It lists through countless diagrams whatever is connected to whatever.. which reminds me.. did you NOT make a note of what goes back where when you dis-sassembled the Qjet?
Old Apr 28, 2006 | 10:42 AM
1974slcvette
Yes took pictures with the digital cam... I have memorized the emission vacuum hose routing section of the AIM, I've looked at it so many times...
I just started to work my way backwards through the hoses from the Vacuum Advance, to the carb... Guess I'll have to pull the carb again.
Thanks for the suggestions.
Old Apr 28, 2006 | 10:44 AM
1974slcvette
I matched it up with the one I pulled out. Maybe Bubba rebuilt it before I did, and it's been the wrong gasket since.
Thanks Chuck
Old Apr 28, 2006 | 10:53 AM
big_G's Avatar
big_G
I believe that on ported vacuum the reading at idle is almost zero, increasing as the throttle is opened.
Old Apr 28, 2006 | 11:37 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Big G is correct,..you won't see vacuum from there at idle,..it pulls it's signal from above the primary butterflies, which are closed (or almost) at idle.
There's another option on the lower-front driver's side of the carb that pulls vacuum full time.
Some use full-time (manifold) vacuum to run their vacuum advance and some use the ported set-up shown in your photo.
To Wrong gasket????
