Wiring new cd player?
Old Apr 27, 2006 | 02:09 PM
72Tornado's Avatar
72Tornado
Default Wiring new cd player?
Ok, so I just got a good deal on a Kenwood EZ-500 off eBay. What will I need to wire it correctly? I looked on Crutchfield and they don't offer any harness for my vehicle (72 coupe)...help?
Will I just have to cut the wires connecting the current tape deck and splice them with the wires from the CD player or what?
Also, I'm going to buy the bezel to for a clean installation, and I know I have to cut the original bezel...but just how is the new bezel attached? Sorry for the stupid question...
Old Apr 27, 2006 | 02:19 PM
soccer794's Avatar
soccer794
I just completely rewired it straight to the speakers. Not very hard to do and helped clean up the old wires. If you do just cut into the old wires I would recommend soldering the wires, you don't want them coming lose.
Old Apr 27, 2006 | 02:49 PM
72Tornado's Avatar
72Tornado
What about the antenna and wires not connected to the speakers, i.e. power wire?
Old Apr 27, 2006 | 03:33 PM
ShaneLU97's Avatar
ShaneLU97
Your antenna will likley plug right into the back of the new CD player (mine did and I have a 73) so no splicing there. As for power, you will need a multimeter to find the ground, a constant 12v source and a switched 12v source and hook those up to the appropriate wires on the CD player per the wiring diagram.
Shane
Old Apr 27, 2006 | 03:39 PM
72Tornado's Avatar
72Tornado
Shane
Ah, okay. Thanks a lot for the help!
Old Apr 27, 2006 | 03:44 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Your switched power source for the radio will be a yellow wire.
An unswitched power source will be an oroange wire, like the clock or cig lighter.
Don
Old Apr 27, 2006 | 03:53 PM
72Tornado's Avatar
72Tornado
Don
Man you guys rock. Thanks for the tip!
Old Apr 27, 2006 | 04:02 PM
Jims79's Avatar
Jims79
Just in case you still need help. cut the old plug off the wire setup for the radio (keep it) then use the wire setup off the new CD player & splice together. it should be easy to setup the front & rear speakers then the two hots. (one full time for clock & one turn on w/the key) the antenna lead should be the blue wire off the CD. Easy job.
Old Apr 27, 2006 | 04:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You should be able to get a plug that will directly hook to the old plugs. Try Wal-Mart or the Corvette vendors.
Old Apr 27, 2006 | 09:42 PM
vetsvette2002
Don't forget raido shak
Don
Old Apr 28, 2006 | 12:31 AM
terry82's Avatar
terry82
thats the cd player i want should look good in you car
Old Apr 28, 2006 | 03:55 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Call Crutchfield and ask. They have a lot of stuff that's not listed (unless they've really, really expanded the online catalog since the last time I dealt with them).
Old Apr 28, 2006 | 01:31 PM
78pacer's Avatar
78pacer
Tornado, You may want to consider an amplifier. You can mount a nice unit against the rear wall and its out of sight from prying eyes. It will really improve sound quality with a little additional 'punch'. Now is the time to do it if your ambitious.
Mike
To Wiring new cd player?
