Window Quit on me
Old Apr 29, 2006 | 12:26 AM
corvette79owner's Avatar
corvette79owner
Default Window Quit on me
Hey people; can anyone tell me why my pass side window all of a sudden quit workin? Fuse? Wire? Motor? Where do I start? And please save the sarcasm. lol I rolled up windows to go for lunch & when I came out the one wouldn't do anything.
Old Apr 29, 2006 | 12:28 AM
SIXFOOTER's Avatar
SIXFOOTER
start with the fuse, if ok go to the switch, most likely failure spot. The connection on the back gets wet, corodes, etc. clean it up and see what it does
Old Apr 29, 2006 | 03:49 AM
c3 in hawaii's Avatar
c3 in hawaii
you should also check the plug to the window motor, mine fell out once and went thru the whole fuse/switch method to find out the plug had came loose. you will have to pull the door panel though.. good luck
Old Apr 29, 2006 | 07:10 AM
rodesmg's Avatar
rodesmg
mine vette sit alot, and right side window sticks off and on, i just spray some wd 40 on the switch and you good to go.
Old Apr 29, 2006 | 06:29 PM
corvette79owner
Thanx for the info guys. I'll let u know how it goes.
To Window Quit on me
