C3 interior help!
Old May 1, 2006 | 11:16 AM
monza_man's Avatar
monza_man
Default C3 interior help!
Does anyone know if the rear compartment area is the same for a '69 corvette as it is in a 78-82? I just need to know if the rear fender wells have the same contour to them and so forth. I've only seen pictures but they look the same. Can anyone with a 68-70 vette and 78-82 vette please check for me? Thanks in advance!
Old May 1, 2006 | 11:20 AM
CGGorman's Avatar
CGGorman
Shoot an email to DeWitts. They do/did manufacture the parts and should be able to tell you.
Old May 1, 2006 | 11:52 AM
mooneyd's Avatar
mooneyd
I don't think they are the same. The earlier ones had 3 compartments and the later had 2 compartments. As far as the shape around the wheel wells I can't help you there.
Old May 1, 2006 | 11:58 AM
CGGorman's Avatar
CGGorman
The compartments are different, but I believe the opening in the floor pan and inner fenders are the same. I'll bet you can swap one style for the other.
Old May 1, 2006 | 12:19 PM
monza_man's Avatar
monza_man
Thanks for the replies! I 'm mostly interested in the area behind the compartments and the shape of the fender wells. I found a custom box for 6x9's that I would like to put in my '69. The box is made for a 78-82 but as far as I can tell the very rear section of the interior is the same for both.
Old May 1, 2006 | 12:32 PM
rihwoods's Avatar
rihwoods
I just went and measured both my 69 and 78 rear cargo area....both measure 36" between vertical (inside) fender well surface..you should be ok...
Rich
Old May 1, 2006 | 12:35 PM
monza_man's Avatar
monza_man
Wow thanks a lot! That helps me out a ton!
Old May 1, 2006 | 12:38 PM
rihwoods's Avatar
rihwoods
Your welcome..
Old May 1, 2006 | 03:17 PM
Bangkok Dean's Avatar
Bangkok Dean
Don't forget to post some pictures when you get if fitted
Old May 1, 2006 | 05:56 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You can put a (3) door unit into the 79-82, but not the other way around. They both are the same size but the corner notch is different and the two door package has the handles molded into the trim. This handle will hit the top of the wall behind the sets.
Old May 2, 2006 | 12:26 PM
IrishJoker's Avatar
IrishJoker
Is that the $199.99 box from Mid-America or Eckler? If it is - and you store you T-tops in the cargo area - they will not fit with that box. Ask me how I know
Old May 2, 2006 | 01:32 PM
monza_man's Avatar
monza_man
Nope I'm looking at a different box. It is a 2 piece box that pressure fits into each rear coner so the speaker faces forward at an angle. They are $99.00 plus shipping.
Old May 2, 2006 | 01:56 PM
TXwayno's Avatar
TXwayno
Could you share with us where you are getting those?? I might be interested in something like that as well.
Old May 2, 2006 | 03:31 PM
monza_man's Avatar
monza_man
Yep I have the web address saved in my favorites folder on my cpu at home (I'm at work now). I'll post it tonight when I get home. They even come carpeted for the $99.00
Old May 3, 2006 | 09:59 AM
monza_man's Avatar
monza_man
Here's a link to the boxes I'm talking about:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old May 3, 2006 | 01:51 PM
TXwayno's Avatar
TXwayno
Old May 3, 2006 | 03:25 PM
monza_man's Avatar
monza_man
These will sound better than the box ecklers, etc sells for $200 since the box they sell is sealed it will hinder the bass response of the speakers a lot. Just thought I should add that as well.
To C3 interior help!
