My Voltage gauge on my 80 had a habit of stopping at 12 volts when first started.A tap of the throttle pushed it up to 13.5.No problem.I have electric fans with powermaster alt 120amp.Its only about 2 years old.
Recently {today} I noticed the gauge doing the same thing except when I tapped the throttle it didnt jump up to 13+.I drove about 5 minutes down the freeway before the gauge needle woke up to where it shoud be.
Is this a sign of a serious problem? The battery is 4 years old.Anyone have a similiar issue.Id like to prevent being stranded with a little prevenitive maintinence.
The car started fine,ran fine,no accessories were on during this issue.
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
you sure its guage and not the carging system itself?
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Check your belt...get the battery load tested...take the alt off have it checked as well...sounds like you may have a faulty voltage regulator...most parts supply places test stuff for free!
