From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by Corz
meh.. what can you do. My dad an I are going to tag team the car starting tomorrow night.. he's gunna tackle whats left under the hood, I'm gunna fix my hood, and what ever else is needed under the car
well if you cant match the vacumming color what change do you have getting the vacuuming wires all back in the vacuuming right vacuuming places
when the vacuum are you vacuum gonna start that vacuuming vette, you vacuum vacuum
tomorrow..
my dad (electical engineer) is going through bubbas work. I finished up my rear suspension tonite (kybs all the way around)
tomorrow my dad and I are gunna finish wiring it, (should only take a couple hours) bleed brakes, put on my junker hood (the one with the stripe) and give it a shakedown run
I feel your vacuuming pain. color blending Is almost an art . If I read your post right did you say you were color sanding the base? If you were that could be the problem If it is metalic. I dont think it is reccomended. best of luck ......murray
