... Norval, I can spot many of your innovative custom changes, but what
are the two brackets welded to the frame rails - just at the front of the floorboards ?
They look like receivers for your jack or jack stands.
Guys did you notice my center link?? Look at the original holes for the inner tie rods and where I had to move mine so I could achieve Zero bump. The hole is moved higher and in 3 inches per side to allow a longer tie rod sleeve. Our cars need this longer sleeve to stay linear in bump.
I cant believe that the undercarriage of your car is that clean. Mine is an oil pit compared to that. I cant find the time to clean the inside of the car and now I see what the undercarriage should look like.
Man,....I have a lot of work ahead in order to catch up with this.
Why do you suppose the factory didn't design it this way in the first place?
