gear lube?
Old May 9, 2006 | 05:30 PM
elecriciandude's Avatar
elecriciandude
Default gear lube?
i hope this isn't a technical question. where can i go local to get the lube and additive for my rearend, any brand,etc and how much ,thxs,Terry
Old May 9, 2006 | 05:56 PM
stingr69's Avatar
stingr69
90 wt gear oil from any parts store and a bottle of limited slip additive from the GM parts counter required. Buy 2 bottles in case you need more than 1.
-Mark.
Old May 9, 2006 | 06:18 PM
elecriciandude
thxs for the reply
Old May 9, 2006 | 07:23 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I'm running Schaeffer's after folks with noisy GM truck diffs had success in quieting them down. It helped quiet my diff. Their website has a list of sources.
http://www.schaefferoil.com/gear_oils/267.html
Old May 9, 2006 | 07:34 PM
turbo78vair's Avatar
turbo78vair
I got my lube from GM dealer parts counter. Two bottles of gear lube and two smaller bottles of additive.
Regards
Gary C '78 Pace Car
Old May 9, 2006 | 08:26 PM
crazywelder's Avatar
crazywelder
My '02 Z rear end has been rebuilt twice under warranty and the dealer uses synthetic with no additive. They say the additive is not needed with synthetic lube. Lots of other noises but never had any posi clunking.
Old May 9, 2006 | 10:35 PM
PRNDL's Avatar
PRNDL
GM gear lube and GM limited slip differential additive from my local Chevy dealer. It is easier if you have a part # for both products. Some of these parts depts have no clue.
Old May 9, 2006 | 10:42 PM
vairxpert's Avatar
vairxpert
Castrol gear lube from AutoZone. Right on the same shelf they also have the Posi additive for a few bucks and it states right on the tube that it's compatible with the GM # (which I can't think of off the top of my head). Nice just to get it all in one place.
Old Jul 28, 2006 | 08:22 PM
pdege's Avatar
pdege
Default gear lube
Where is the oil fill??
What is the capacity?
Old Jul 28, 2006 | 08:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have always put the GM additive and then Mobil synthetic gear oil in mine. No problems yet.
To gear lube?
