Hobart Handler Wire-Feed Welder
Old May 16, 2006 | 12:18 PM
CrossedFlags77's Avatar
CrossedFlags77
Default Hobart Handler Wire-Feed Welder
http://www.northerntool.com/webapp/w...39&R=200318739
Has anybody used this welder? I can get a pretty good deal on one and was wondering what you guys thought. I just want it for welding up brackets and maybe an exhaust or two. Seems like it would good enough to be spreader bar mounts and such.
Old May 16, 2006 | 12:31 PM
crazywelder's Avatar
crazywelder
This welder can not be converted to gas, you'll want to use gas for cleaner welds. The next up model from Northern is $359 and the gas kit is $82.99. Hobart, Lincoln, and Miller all offer good home size machines.
Shop around at Home Depot for a complete package in one box (gas kit, helmet, regulator, etc.) for a better deal. Also, try your local welding supply, they might have a good deal and you can build a relationship with them which can be very helpful down the road when you need info or advice since you will be buying supplies from them anyway.
Old May 16, 2006 | 12:37 PM
DaveL82's Avatar
DaveL82
Steer clear of any unit that can't be converted to gas. While flux core is OK for thicker metals such as 3/16 it produces more splatter (a real pain when welding on or under a car).
Look for a gas sheild unit. I deal with Garland Welding supply however I picked up my 125 volt Miller MIG unit used but bought my Plasma cutter new from them. They might have some deals going on regarding a new MIG one though.
dave
Old May 16, 2006 | 01:14 PM
comp's Avatar
comp
Garland ,,is that local to you ???
Old May 16, 2006 | 01:49 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Your more than welcome to borrow my Millermatic 135 or just bring it by and I'll weld it. I owe you a favor anyway.
Old May 16, 2006 | 02:18 PM
DaveL82's Avatar
DaveL82
Comp - yes local to DFW TX
Old May 16, 2006 | 04:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Avoid no-gas units. I have a 110v Clarke with the gas conversion kit that I really like. My dad has the 220v Hobart Handler - that's a really nice welder.
Old May 16, 2006 | 04:29 PM
jpatrick636's Avatar
jpatrick636
A combination of gas and flux core makes the best weld.
Old May 16, 2006 | 04:34 PM
CrossedFlags77
Thanks for the info! I guess I will keep looking.
Old May 16, 2006 | 05:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's not exactly recommended. I get great welds from gas with solid-core wire for gas.
Old May 16, 2006 | 06:13 PM
MoneyPit's Avatar
MoneyPit
When talking about a 110-115v vs 220-225v it looks as though you are only get a 1/16" more out of the 220 (3/16 mild steel vs. 1/4 (220). Is it worth the money to get the extra 1/16 of inch out of the 220, when we are talking a basic home shop?
Old May 16, 2006 | 06:18 PM
comp's Avatar
comp
i think part of it is the duty cycle,,,how long it can run at higher amp's
Old May 16, 2006 | 06:28 PM
MoneyPit's Avatar
MoneyPit
Yeah, I kinda thought that. But is it worth the money?
Old May 16, 2006 | 06:32 PM
comp's Avatar
comp
if you can afford it ,,i'd do it ,,,,
Old May 16, 2006 | 06:51 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Flux sucks , I have better welds with solid wire and no gas.
Old May 16, 2006 | 07:04 PM
zwede's Avatar
zwede
I bought a Hobart 140 that already has the gas kit last year from this guy off ebay:
http://cgi.ebay.com/HOBART-HANDLER-1...QQcmdZViewItem
Great dealer! He had the best price and shipped the next business day. The Hobart has worked perfectly. I also bought a miller auto-dimming helmet from the same dealer and I highly recommend an auto-dimming helmet.
Old May 16, 2006 | 08:26 PM
shafrs3's Avatar
shafrs3
I bought the 220VAC for the added power needed when welding thicker aluminum. Since aluminum absorbers heat faster you might need the extra power if you anticipate working with it.
Old May 16, 2006 | 09:42 PM
DaveL82's Avatar
DaveL82
The link Zwede posted is a good price when you consider it comes with the gas kit. I'd go for that and then weld up a cart since it would be a good practice.
I had a spare helmet so just bought the auto tint lens at Garland.
The 110V unit will do most any job you'll need up to 3/16. For 3/16 I did use flux core for a bit better penetration on my coilover brackets however for all other jobs and welding on the car directly I use gas shield. Flux wire was recommended by Garland Welding supply for 3/16and it worked great.
Now all I need is a TIG, and small Mill/Lathe combo, convert the spare bedroom to a machine shop and so on and so on...
To Hobart Handler Wire-Feed Welder
