Max rear tire width
Old May 16, 2006 | 03:22 PM
revel_inmy_loss's Avatar
revel_inmy_loss
Default Max rear tire width
I am just making sure I can run a 275/60/15 in the back of my '78.
will it fit a stock car? and will it fit with my new rear 360Lb spring lowered about an inch? anyone running them let me know. espesially if you are lowered!
thanks
Old May 16, 2006 | 04:02 PM
CrossedFlags77's Avatar
CrossedFlags77
I am running 275/60/15 on the rear and it works well and they fill up the rear wheel well nicely. The only problem I have is the fender rubbing ever so slightly on really hard bumps but this is because the wheels is moved out half an inch with a spacer to clear the caliper. If I wasn't running the spacers I would have no problem at all with an rubbing issues. What wheels are you running? If you are running stock wheels you shouldn't have a problem.
Old May 16, 2006 | 04:27 PM
revel_inmy_loss
I am running these wheels... I am drawing a blank on who made 'em but they have been on the car since new and I believe they have an offset very close to stock...the car will be lower though..suspension arrived today!!!
Old May 16, 2006 | 04:51 PM
IMA 66's Avatar
IMA 66
check this out on the 275/60/15....looks like the only possible issue is the parking brake brakcet.
http://www.corvettefaq.com/c3/MoreBite.pdf
Old May 16, 2006 | 06:40 PM
holley505's Avatar
holley505
yup
got them on mine.
Old May 16, 2006 | 06:49 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Ansen sprints
Old May 17, 2006 | 10:47 AM
revel_inmy_loss
Old May 17, 2006 | 10:48 AM
revel_inmy_loss
So Is anyone lowered with 275's in the back? And would you guys agree that these wheels have a stock offset?
Old May 17, 2006 | 11:07 PM
84rzv500r's Avatar
84rzv500r
I'm lowered with 325's in back and have stock backspacing on 15 inch rims
To Max rear tire width
