production numbers
Old May 20, 2006 | 01:50 PM
alaskacorvette's Avatar
alaskacorvette
Default production numbers
Does anyone have information on '71 model year production numbers? Specifically how many big block roadsters were built. How many of those were auto verses 4 speed. Is there any trim code info as well? Thanks, Jim.
Old May 20, 2006 | 01:51 PM
LittleJake's Avatar
LittleJake
19437 Base Corvette Sport Coupe 14,680 5,496
19467 Base Corvette Convertible 7,121 5,259
n/a Custom Interior Trim 2,602 158
A31 Power Windows 6,192 79
A85 Custom Shoulder Belts (std with Coupe) 677 42
C07 Auxillary Hardtop (convertible only) 2,619 274
C08 Vinyl Covering (for Auxillary Hardtop) 832 63
C50 Rear Window Defroster 1,598 42
C60 Air Conditioning 11,481 459
n/a Optional Rear Axle Ratio 2,395 13
J50 Power Brakes 13,558 47
LS5 454ci, 365hp Engine 5,097 295
LS6 454ci, 425hp Engine 188 1,221
LT1 350ci, 330hp Engine 1,949 483
M21 4-Speed Manual Transmission, close ratio 2,387 0
M22 4-Speed Manual Transmission, close ratio, hvy dty 130 100
M40 Turbo Hydra-Matic Automatic Transmission 10,060 0
N37 Tilt-Telescopic Steering Column 8,130 84
N40 Power Steering 17,904 115
P02 Deluxe Wheel Covers 3,007 63
PT7 F70x15 White Stripe Tires, Nylon 6,711 28
PU9 F70x15 White Letter Tires, Nylon 12,449 42
T60 Heavy Duty Battery (std with LS5, LS6 engines) 1,455 15
UA6 Alarm System 8,501 31
U69 AM-FM Radio 18,078 178
U79 AM-FM Stereo Radio 3,431 283
ZR1 Special Purpose LT1 Engine Package 8 1,010
ZR2 Special Purpose LS6 Engine Package 12 1,747
1971 Corvette Exterior Color Choices
CODE EXTERIOR QUANTITY
972 Classic White 1,875
905 Nevada Silver 1,177
976 Mulsanne Blue 2,465
979 Bridgehampton Blue 1,417
912 Sunflower Yellow 1,177
973 Mille Miglia Red 2,180
983 Brands Hatch Green 3,445
987 Ontario Orange 2,269
988 Steel Cities Gray 1,591
989 War Bonnet Yellow 3,706
1971 Corvette Interior Color Choices
CODE COLOR
std Black Vinyl
402 Black Leather
407 Red Vinyl
412 Dark Blue Vinyl
417 Saddle Vinyl
420 Saddle Leather
423 Dark Green Vinyl
Old May 20, 2006 | 11:17 PM
alaskacorvette
Default production number source
LittleJake, What is your source for info? It's great stuff to know, none of my books have very detailed information. Jim
Old May 21, 2006 | 01:27 AM
Tom73's Avatar
Tom73
Looks like the numbers out of the Corvette Black Book or from CorvetteActionCenter.com
Problem is, there are no combo numbers available. So will just have to do some math ratios to get a idea of what might have been.
tom...
Old May 21, 2006 | 02:30 AM
Flagstaff_Vette's Avatar
Flagstaff_Vette
Well if ya take ratios, and the rarest option ya got, you can sorta see the rarity of your particular vehicle.
The rarest option I have is the C08 Vinyl Covering for Auxillary Hardtop. There were 832 corvette convertibles made with this option, that was a $63 option. Whoa big spender.
But that means I have one of 832 1971 Corvettes, made like mine. And since the vinyl hardtop was usually a high optioned car, and mine doesnt have tilt/tele, a usual high option, or power windows, mine MIGHT be even rarer.
But ya never know. We'll probably never know. GM spent alot of money looking in warehouses looking for old records of the Vette when the Corvette Museum project was being constructed. Back then, they just threw out the records after a while.
But they could not find production numbers for our year. So, I can only theorize I have one of 832.
Old May 21, 2006 | 02:33 AM
Flagstaff_Vette
I also had the AM FM Multiplex Stereo radio. The original radio is gone, but I found the Multiplex unit still behind the dash.
Old May 21, 2006 | 04:56 AM
early shark's Avatar
early shark
convertibles at 33%, manual transmissions at 52%, big blocks were 25%, as an average.
Old May 21, 2006 | 10:31 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There's new talk of records that might be found.
My 71 is highly optioned with the vinyl hardtop, am/fm stereo, tilt/tele column, pwr steering/brakes/windows, air, alarm, leather, and the rarest of options for a convertible, custom shoulder belts with only 677 installed.
Old May 21, 2006 | 11:36 AM
PRNDL's Avatar
PRNDL
for about the 100th time, here are two websites that have production data. There are quite a few more websites around that have similar information:
http://www.idavette.net/facts.htm
This website has more info, but only up to the 72 model year:
http://www.rowleycorvette.com/vettestats.html
Old May 21, 2006 | 04:40 PM
Flagstaff_Vette
There are alot of these pages like above. There are NO records as to how many cars EXACTLY like your were made. All you can do is get close. Find your build sheet. That will tell you what the car came with.
To production numbers
