Rear spring
Old May 20, 2006 | 05:11 PM
virtue4u's Avatar
virtue4u
Default Rear spring
On my 77 I am going to replace my 7-leaf rear spring with a new 7-leaf replacement spring. Please provide any cautionary warnings or tips before I start this job. Does anyone have a step-by-step procedure that they can post? Thanks.
Old May 20, 2006 | 05:16 PM
TonySinclair's Avatar
TonySinclair
http://www.corvettefaq.com/c3/RearMonoLeaf.doc
Old May 22, 2006 | 09:27 AM
virtue4u's Avatar
virtue4u
Originally Posted by TonySinclair
Thanks. The reason I must change the spring is because I noticed that the end of the third and fourth leaves (counting from the bottom) broke off on one end, making the fifth leaf longer than the third and fourth. Has anyone ever heard of this before?
Old May 22, 2006 | 10:51 AM
rihwoods's Avatar
rihwoods
No...but you might consider Guldstrands replacement 7 leaf...I bought the one that is 1 1/2" shorter than stock..you gain 3/4" more room at tires with spring bolts....well built. Also it is slightly stiffer than stock FE7 spring...if you look close at pic below, you can see spacers they use instead of the old liners between the leafs to prevent friction.....
Rich
Old May 22, 2006 | 11:32 AM
kdf1986's Avatar
kdf1986
I had a similar problem with my 1972. One of the leaf springs broke where it would normally extend from the group of springs itself.
I replaced this with a stock spring.
The installation was very easy. Use jack stands to get the car up in the air and support it. You will need to use a jack to support the spring once you remove the bolts from the trailing arm.
kdf
Old May 22, 2006 | 11:48 AM
Emeightch's Avatar
Emeightch
Don't forget about the C-Clamp so the jack doesn't slide up the spring.
Old May 22, 2006 | 12:56 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
Just put a composite spring from VB&P on my 76 on Saturday. Piece of cake.
Old May 22, 2006 | 07:23 PM
84rzv500r's Avatar
84rzv500r
I just replaced a 1 year old 7 leaf with the rubber spacers for the shorter G*ldstrand.
No comparison. G*ulstrand is hands down a better spring.
Took less than 30 minutes to swap the spring.
I'll post some pics
Old May 22, 2006 | 07:46 PM
rihwoods's Avatar
rihwoods
I'll post some pics
I remember you saying you going to talk to Guldstrand...
Rich
To Rear spring
