how to replace alternator belt
Old May 20, 2006 | 08:48 PM
jag2241's Avatar
jag2241
Default how to replace alternator belt
can somebody help me I'm trying to put on a new belt for my alternator. The belt for my alternator snap and I don't know why. I know where the belt goes but I don't know how to put it on.
Old May 20, 2006 | 08:51 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
you have to remove the power steering pump belt first. Then loosen the bolt on the alt and slide it all the way over towards the center of the car. Slide the alt belt over the fan and hopefully you can get it on. If you don't have enough slack try taking the bolt all the way out of the alt and push the alt all the way until it hits the valve cover and slide the belt on.
Old May 20, 2006 | 08:54 PM
jag2241's Avatar
jag2241
thanks i will try that.
Old May 20, 2006 | 11:19 PM
jag2241's Avatar
jag2241
I have another question about the belt, how tight should it be? Last time I think the person who did the belt did it too loose so it snaped.
To how to replace alternator belt
