Power window wire routing/ pic request
Old May 22, 2006 | 12:46 AM
70 LS1's Avatar
70 LS1
Default Power window wire routing/ pic request
Looking to add power to the door on my 1970. How do the wires run between the door and the jamb? Do they fit through a tube or is it part of the wiring harness? Pleas post some pics of what it should look like.
Old May 22, 2006 | 01:56 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Gotta fish the wire through the tube. But first you need a wiring diagram to check the the existing wiring, the leads may already be there.
Old May 22, 2006 | 10:13 AM
70 LS1's Avatar
70 LS1
What tube? Does that mean it is not part of the harness? Thats the pic I am after.
This will be for custom power locks and I am redoing the entire electrical system in the car.
Old May 22, 2006 | 12:18 PM
Buzzardz_vette's Avatar
Buzzardz_vette
The wires are part of the power window harness and go through a rubber tube between the door and the front jam. I just picked up the tube from Zip Products and installed one myself. Easy to do. Wires go through a hole above where the kick panel goes, through the tube and into the door, then along the bottom to the window motor. If you need pics, let me know and I'll try to take some tonight.
Old May 22, 2006 | 01:13 PM
70 LS1's Avatar
70 LS1
I could use a pic of the tube, plus a part#. Can't seem to find it in any of the catalogs.
Old May 22, 2006 | 01:15 PM
bluesilver82's Avatar
bluesilver82
It is just a rubber flexible boot that leads from the door pivot/hinge area to the body and I am almost positve you route the wires through the dash into the center console.
Old May 22, 2006 | 02:24 PM
Buzzardz_vette
Here's the part at Zip:
http://www.zip-products.com/Zip/prod...F6A6553BD0963B
It is a little wider than the stock conduit so it's easier to run the wires with the connector on it.
Old May 22, 2006 | 03:01 PM
SIXFOOTER's Avatar
SIXFOOTER
Ecklers
http://www.ecklers.com/product.asp?p...dept%5Fid=1679
Old May 22, 2006 | 03:05 PM
NHvette's Avatar
NHvette
I will be doing the same thing ... glad I have a set of originals.
$15 for a rubber tube, and it won't even prevent the spread of sexually transmitted diseases.
Old May 22, 2006 | 03:17 PM
70 LS1's Avatar
70 LS1
Thanks for the links and pictures. I am going to be completely rewiring the car late summer and will be adding a new fuse panel, new gauges, power locks, and a passive keyless entry. Just trying to get all the little details sorted out before I start.
To Power window wire routing/ pic request
