C3 Trivia
Old May 22, 2006 | 02:05 AM
redson's Avatar
redson
Default C3 Trivia
C3 Trivia- 1968 to 1982
Pontiac almost beat Chevrolet to the Coke bottle design body, with their 1965 Banshee, a two seater convertible sports car that would have been hefty competition for the Corvette. GM stopped it, and then Pontiac president John DeLorean later became president of Chevrolet.
T-top does not refer to the shape of the roof, but rather it is short for Targa Top. The original design was a pure Targa but body flex demanded the center bar, discovered late in the design.
Due to policy changes in Chevrolet, Corvette was treated like all other car lines for the first time, and quality dropped drastically. With bad publicity in most magazines, policy was re-thought and Chevrolet quickly restored independence and quality to Corvette within a few months, but all 1968s carry the stigma of being "the worse quality" of all Corvettes.
All big block manifolds were redesigned to actually sink into the lifter valley as the hood clearance was less than in '67 and back. As such, a 1965 to 1967 big block intake manifold won't fit in a 1968 or newer Corvette with a stock hood and air cleaner.
The exception to the above was the L-88. It retained the high rise manifold and also received a special hood, which was externally different this time.
Emission control equipment was installed on the first 1968's in the fall of 1967 even though the federal law required it only as of January 1, 1968.
1968 was the first year AM/FM stereo was offered as an option.
1968-1972 the coupe's rearwindow was removeable for more of a true convertible experience
The Sting Ray name was not used on the 1968 Corvette, but returned in 1969… Spelled Stingray.
Corvette had its first all aluminum engine in 1969 as the ZL-1. It was not the first GM automobile to do so, beaten by the Corvair in 1960 and the Buick 215 V8.
In 1969, the ignition lock was moved from the dash to the steering column. It would remain there until 1997 when it was returned to the dash.
The LS7 engine option, which was never installed in the 1970 Corvette was $3000.
No Corvettes were painted Black at the factory from 1970 to 1976.
The only outside difference between the 1971 and a 1972 Corvette is the appearance of the amber front turn signals and vertical chroming on the egg-crate grills both on the 1972 - that's it. Minor stuff most people miss.
1972 was the only year for Corvette "Big Block" engines in the 1968 to 1972 range to have no horse power sticker on the air cleaner lid.
"Pewter Silver" was only offered as an exterior color in 1972.
The 1970 - 1972 Corvettes were the last to feature chrome bumpers front and rear. In 1973, the front bumper changed to body-colored flexible plastic. In 1974 the rear bumper followed suit.
In 1973, aluminum wheels were again available as an option, but the same problem that plagued the 1963 aluminum wheels, the inability to hold air, kept these out of the hands of customers until 1976.
The rear view mirror in the 1974 Corvette was increased to a width of 10".
The last true dual exhaust was installed in 1974, after that, everything went through a catalytic converter.
1974 rear bumper was 2 pieces, 1975-1982 used a one piece unit.
The awesome 454ci engine was only offered for 5 years.. 1970, 71, 72, 73, and 1974
Gymkhana Suspension was first introduced in the 1974 Corvette.
1974 was the last year the Corvette would be produced to run on "leaded" gasoline.
1975 first year for HEI distributor.
1975 was lowest production year for convertibles for those years that offered both convertibles and coupes.
1976 Corvette used the same steering wheel as a Chevrolet Vega for the "Sport Wheel" Option.
1977 last year for the notch back shark.
In 1977 crossed flags returned to the nose and sides of the Corvette.
1977 saw the redesign of the center console to accept standard Delco radios, the first year that Corvette didn't have a Corvette only radio.
The '78 Pace Car was "Black and Silver" was because it photographed well. Back then, most magazine articles and ads were still done in Black & White!
The body in 1978 was widened in the rear fender area. This was discovered by customizers when converting '78 and newer coupes to convertibles after the convertible production ended in 1975.
1979 Corvette's highest production year.
By Federal mandate, the 1980 Corvette was the first Corvette to have an 85 MPH speedometer.
1981 the first Corvette to use a computer.
The 1981 Corvette had two cooling fans to increase engine power.
In 1981, Corvettes were produced with two different types of paint. Lacquer was applied at the St. Louis plant, and enamel was applied at the new Bowling Green plant.
In 1982 fuel injection reappeared in the Corvette after a 17-year hiatus.
Old May 22, 2006 | 04:21 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Interesting facts there.
Interesting reason.
Wasn't that the beloved Jimmy, Mr Peanut, Carter era?
Old May 22, 2006 | 05:00 AM
PhotoVette1's Avatar
PhotoVette1
No, the 55 mph speed limit was enacted by the beloved "I am not a crook" Nixon on January 2nd, 1974.
Old May 22, 2006 | 05:14 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
My copy reads 1980 not 1974.
Old May 22, 2006 | 05:23 AM
PhotoVette1
"...The year was 1973 and Richard Nixon signed the bill into law. Because he supported the new law, however, it was Jimmy Carter that most people "blamed" for the law. It was President "I kept it in my pants" Clinton who reversed this law..."
Old May 22, 2006 | 05:41 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
A little defensive aren't we?
So then the answer to my question is YES!
Old May 22, 2006 | 05:57 AM
PhotoVette1
No! I was trying to be amusing an this early Monday morning.
Old May 22, 2006 | 07:34 AM
PYRO1's Avatar
PYRO1
Cruise-In VII Veteran
Thanks for the facts!
Old May 22, 2006 | 07:49 AM
rihwoods's Avatar
rihwoods
I heard that the 78 two tone...Silver SA..(13/07) was originally targeted to be the Pace Car..but very difficult to photograph...hence the Black/Silver Pace Car scheme ...???
Rich
Old May 22, 2006 | 10:22 AM
smthnpls's Avatar
smthnpls
It's all great info... thanks for sharing it
Old May 22, 2006 | 02:24 PM
markbett's Avatar
markbett
You forgot the most important piece of trivia:
In 1990 forward, all remaining C-3's began costing their owners lots of money. A strategy thought of by the former GM presidents.
Old May 22, 2006 | 02:38 PM
rbird's Avatar
rbird
St. Jude Donor '06
Wait... on Two Guys Garage, they said that because corvette parts are so plentiful, prices for parts are at rock bottom. So everyone go buy a vette and save $$$!
Old May 22, 2006 | 05:35 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Good stuff,..a couple of notes:
HEI was actually installed on late 74 cars.
The aluminum BB, the ZL-1, also went in to 69 Camaros in 1969 and only two Vettes,..of which one is known to still exist,..a yellow one I believe.
Old May 22, 2006 | 05:46 PM
tshort's Avatar
tshort
CI 7-8 Veteran
What about that orange and blue Mobil ZL-1? Is it a fake? I've seen it on many different websites and here a few times.
Old May 22, 2006 | 07:38 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
That's a bunch of baloney, prices keep going up.
Old May 22, 2006 | 11:53 PM
Tom73's Avatar
Tom73
Except for Calif where emission equipment started 2-3 years sooner.
The Sting Ray name was not on the car but ads and Chevy lit refered to it as the 1968 Corvette Sting Ray.
Black was not listed as a factory color but it was available as a COPO option. Trim plate would show SPEC or SPECIAL. Some were painted black or other special color while others came from the factory in primer and the dealer painted them whatever the customer wanted.
True as far as the statement goes, 68-72; but the big block continued on till 74 and the '73 and '74 did not have a HP sticker on the air cleaner.
Not sure about the paint type but the Bowling Green plant paint was the start of the base coat/clear coat paint job.
tom...
Old May 23, 2006 | 08:44 AM
1971Coupe's Avatar
1971Coupe
The C3 was the only vette around during my school days, up until high school. (68-82)
I like that trivia, they asked me first.
To C3 Trivia
Old May 23, 2006 | 09:24 AM
red topless gator's Avatar
red topless gator
[QUOTE=redson]C3 Trivia- 1968 to 1982
The 85 MPH speedo actually was started in the later 79 models...........LT
Old May 23, 2006 | 10:00 AM
454_71Stingray's Avatar
454_71Stingray
FACT: The C-3 is the only Vette that has curves like a woman, I love those hips.
Old May 23, 2006 | 10:09 AM
Z51JEFF's Avatar
Z51JEFF
Heres a question for somebody,why was the convertable disc after 75 and who was responsible for it?
