Installed my new radiator today and it went pretty well. After reading some of the posts I thought it was going to be a nightmare, but it really wasn't that bad. I did not remove the hood or the fan. I guess in 1980 it was a little easier then earlier models. Coolant lines were a PITA though.
I don't know if someone replaced the radiator in the past but it didn't seem like there were to many seals(Shroud seals,support seals), and that's the only thing I didn't get...a concern?
Well.... yes, the seals are a concern, they ensure that the fan pulls air through the radiator and not around it. Dr. Rebuild has the right stuff in kit form or you can be creative and make your own from some pipe insulation at your local plumbing dept. Use weatherstrip adhesive (3M) to glue the pieces in place.
get the seals and Dr. Rebuild has the best ones.
The bad news is.........you will probably have to pull the radiator again to get them installed but you DO need to have them.
The cooling system on these cars was always borderline at best and those seals are very important to make sure as much air gets thru the radiator as possible. As mentioned, they prevent the air from just bypassing and going around the radiator.
BarryK is the resident expert on radiator removal/installation. After doing 16 times he's got it down to about 7 minutes now. J/K.
Any chance on getting a link to the ones I need? Are there usually more then four seals?
the radiator seal kit is 4 pieces and the top core support seal kit is 3 pieces. you can buy each kit seperatly or a a single big kit which saves you a few dollars I think. i'd just go for the single kit that includes all 7 pieces.
Opps, looking at the linked page i see your '80 is actually 9 pieces, my '78 L82 motor was only 7 pieces.
I wouldn't call me an expert on ANYTHING, but I will say that at this point I can most likely pull my radiator and core support out in my sleep now.
practice does make it go a lot faster also!
Thanks a lot..this helps. I guess I should have questioned this before I put the radiator back in. I guess that explains why it is running a little hot.
