door panel attachment
Old May 23, 2006 | 10:29 PM
gator79's Avatar
gator79
Default door panel attachment
how are the door panels attached on my 71? the ones that came with the car had theese huge screws holding them on, right thru the face of the panel. I have seen some sort of clip for sale how does that work? my new panels only have the velcro llike pieces on them.
Old May 23, 2006 | 10:38 PM
blue_74's Avatar
blue_74
Theoretically, those velcro pieces should shap into similiar pieces on the door itself.
I've never seen those clips come close to snapping together. Believe it or not, those screws through the face of the old door panel are original. There should be three total, one at the upper front panel and two at the upper rear of the door panel. Along the bottom, there should be two clips that attach to the door panel and screw into the bottom of the door.
Good luck!
Old May 23, 2006 | 10:44 PM
gator79's Avatar
gator79
anyone got a pic of their screw locations?
Old May 26, 2006 | 02:18 PM
1971Coupe's Avatar
1971Coupe
Old May 26, 2006 | 02:59 PM
NHvette's Avatar
NHvette
No AIM ? Mine are both at home right now.
Old May 26, 2006 | 03:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
They're in the AIM. Might vary for you since Bubba may have added to or taken from.
Old May 26, 2006 | 03:28 PM
kevinator80's Avatar
kevinator80
After the joke you played on me, I got three words for you: Go riller glue
Old May 26, 2006 | 03:43 PM
ksbunting's Avatar
ksbunting
On my 68 coupe I have one screw at upper front and one at upper rear and then one each on the front and rear clips on the bottom, and all of my Velcro tabs line up perfectly.
With the 4 screws and the Velcro tabs, you should be good and secure.
Kurt
To door panel attachment
