I have been running with 1/4" spacers at the track and on the street for years without incident. I have shattered drive line parts but have had no wheel problems.
The precautions have been mentioned:
Proper length studs.
Tapered lug nuts.
Proper torque and retorque after 25 and 100 miles. Then check every 1000 miles.
Hello,
I had similar issues with my 1986 and putting on year 2000 rims.
Here is what the adapters look like installed. The adapters are
the way to go, not the spacers.
kdf
i agree the adaptors may be the safer way to go except the thickness of em might throw my tires outside my fender wells. not cool
I do not see where there would be an issue with a thin spacer. One of the problems is that adapters need to be a minimum thickness which will make the tires stick to far out.
I believe it would be better to get lugs with a longer shaft than longer wheel studs. It will be stonger, cheaper, and a lot less work. If you go the longer stud route, might as well increase the diameter of the stud as well.
