Roller Rockers
Old May 31, 2006 | 11:03 PM
JustinD's Avatar
JustinD
Default Roller Rockers
What is a good procedure for putting on roller rockers? Tighten the rocker nut by hand until there is no play then 1/2 turn. Or am I missing a step?
Old Jun 1, 2006 | 12:20 AM
Star79's Avatar
Star79
ttt, I'll be needing the answer pretty soon too...
Old Jun 1, 2006 | 12:38 AM
Ironcross's Avatar
Ironcross
Use the same proceedure as the OEM stamped steel rockers. As the exhaust valve closes adjust the intake and as the intake valve opens adjust the exhaust. This always puts you correctly on the heel of the camshaft lobe for the valve your adjusting.
Old Jun 1, 2006 | 07:24 AM
JustinD's Avatar
JustinD
And it is still 1/2 turn past the "no play" point?
Old Jun 1, 2006 | 08:31 PM
C3 Stroker's Avatar
C3 Stroker
I like to go 1/2 turn past "no play", then another 1/4 turn to lock down the poly locks.....personal preference thing.
Old Jun 1, 2006 | 10:05 PM
JustinD's Avatar
JustinD
Ok, I got it. I should be installing my heads in the next day or so if all goes well.
To Roller Rockers
