polishing windshield trim
Old Jun 10, 2006 | 06:54 AM
gator79's Avatar
gator79
Default polishing windshield trim
what is the best way to polish the windshield trim? I bought new upper corners for mine and it is really making the rest of them look bad.
Old Jun 10, 2006 | 07:36 AM
Bob Onit's Avatar
Bob Onit
Been using it for years
http://www.nevrdull.com/
Old Jun 10, 2006 | 08:03 AM
Butch R's Avatar
Butch R
I used a buffing wheel with white rouge.......came out like new in less than a half hour
B.
Old Jun 10, 2006 | 08:12 AM
gator79's Avatar
gator79
B.
what type of buffing wheel? I have one on a bench grinder and I also have a dremel tool. where do you buy the white rouge?
Old Jun 10, 2006 | 08:16 AM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
I think you can get white rouge (white red? as in two grits?) from Eastwood.
Personally; I would try clay...it wont matter if it got on the paint, metal or glass....claying is good for all of those.
GL
Jim
Old Jun 10, 2006 | 08:23 AM
gator79's Avatar
gator79
GL
Jim
what type of clay? the mouldinngs are all off the car
Old Jun 10, 2006 | 08:58 AM
Strats-N-Vettes
Detailing clay...of course, it would be a little harder to use with the molding off...not that it cannot be done...just more tedious.
It would be a lot easier to use the clay with the molding on the car.
but
butt...
Since the molding is off....use NOXOL. Its in a green bottle at part stores.
Its also called "7-metal polish" and is a liquid.
Use that with an old sock turned inside out....stick your hands in the socks like you are wearing gloves, this makes it very easy to polish small things...just like washing dishes...let dry...stick your hands in two more dry socks....then buff.
and; you can use the NOXOL on your polishing wheel....but, slow speed.
Those fast polishing wheels can grip, remove the trim from your hand, and sling it where you cannot find it anymore (remember that thread?)
Also;
If the polishing wheel takes it out of your hand...it might slice your hand severely...causing you to only be able to hold one beer at a time.
or worse;
put a slight kink in your molding/window trim
Jim
Old Jun 10, 2006 | 11:52 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I get my wheels and compounds from ACE Hardware.
Old Jun 10, 2006 | 12:49 PM
Scottys78's Avatar
Scottys78
Old Jun 10, 2006 | 01:29 PM
gator79's Avatar
gator79
my son works for ace hardware, what is the name of the compound?
Old Jun 10, 2006 | 04:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I forget who makes them. Each compound says what it's good for on the packaging. I have a complete set of compounds, and a wheel for each compound - I mark each one with a sharpie so I know what compound is on it. For windshield stainless that's been exposed to flying debris and such, I'd recommend getting some wet/dry super-fine sandpaper (3M brand available at Wal-Mart) in various grits and sand it smooth starting with 600 or 800, and working up into the 1000-2000 range. Then buff. Eastwood sells a nice, short book on the subject of trim restoration.
To polishing windshield trim
