Stinger Hoods
Old Jun 14, 2006 | 09:07 AM
vettasy's Avatar
vettasy
Default Stinger Hoods
Could anyone running a 67 stinger hood on a C3 post a picture. I'm thinking of getting one and want to see how the look.
Old Jun 14, 2006 | 09:55 AM
Niart01's Avatar
Niart01
Default Heres Miy 73
I put the Eckler hood on it last year before I painted it. I really like it.
It draws a lot of comments at car shows. Some like it, some think it is a travesty to change anything. I did what I wanted, and the original hood is stored in my garage for the next owner. I also put in a removable back window, so I have destroyed the "collecter" value.
Old Jun 14, 2006 | 09:57 AM
StingrayDK's Avatar
StingrayDK
Old Jun 14, 2006 | 01:56 PM
danboback's Avatar
danboback
I love the stinger hoods! They look killer!
Old Jun 14, 2006 | 03:11 PM
vettasy's Avatar
vettasy
Is the rear of the scoop open or closed? I'm wondering if it improves air flow over the engine and helps with cooling at all.
Old Jun 14, 2006 | 04:49 PM
68roadster's Avatar
68roadster
They all look good How's the fit and quality of the Ecklers?
Old Jun 14, 2006 | 09:25 PM
Summerfun's Avatar
Summerfun
This was before my new Vortech addition......I liked that hood!
Will soon build a new one similar to that, just wider and a little taller.
Old Jun 15, 2006 | 01:09 AM
danboback's Avatar
danboback
Sweet!
Old Jun 15, 2006 | 06:56 PM
terry82's Avatar
terry82
i love it .its your car do what you like.
Old Jun 16, 2006 | 09:40 AM
Niart01's Avatar
Niart01
Default Eckler Hood
The hood as it comes from Ecklers is closed. Mine is now open. I used my trusty dremel tool and cut the opening before I painted the car. Took about 1 hour. The back of the hood is open also so air is drawn out of the engine compartment. Another side benefit is you gain about 2 inches of clearance so you can run a higher intake manifold. The fit was really great and the hood is very well made and feels about the same weight as the stocker. I only had to mortice the hinges about 1/4 inch and the hood fits perfect. I could not be happier with the hood. The original is tucked away and will be available to the new owner after I have left the planet.
To Stinger Hoods
