rotor thickness?
Old Jun 14, 2006 | 08:54 PM
JoeRags's Avatar
JoeRags
Default rotor thickness?
what is the minimum thickness for stock C3 brake rotors? I've got unusual uneven wear that looks like the rotor might be too thin. Both front rotors approximetley 30mm +/- 0.25mm... or about 1.18"
is this too thin? thinking I need new rotors... these were taken off the old car before the frame off, and stuck back on... yea i know.. flame on.
Old Jun 14, 2006 | 09:07 PM
Gordonm's Avatar
Gordonm
A number should be punched into the rotor for the minimum thickness. If I can remember right anything under 1.2 inches is to thin. Maybe someone can confirm this.
Old Jun 14, 2006 | 09:35 PM
GTR1999's Avatar
GTR1999
Joe,
Rotor thickness new is 1.250" trash is 1.215"
I just did an original set of T arms and the rotors were 1.253" ! plus the runout was dialed in to .001"
Gary
Old Jun 14, 2006 | 10:21 PM
JoeRags's Avatar
JoeRags
guess I now know why my brake pedal is to the floor!!!!
thanks fella's... time for new rotors.. I want custom ones like norval's.
Old Jun 15, 2006 | 12:22 AM
Kilroy1024's Avatar
Kilroy1024
This will not cause the pedal to go to the floor.
Check for leaking calipers or bad master cylinder.
Old Jun 15, 2006 | 12:31 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Double post...
Old Jun 15, 2006 | 12:32 AM
73, Dark Blue 454
...or try bleeding the brakes.
Old Jun 15, 2006 | 09:35 AM
NHvette's Avatar
NHvette
1.18 is too thin to turn again, but won't cause your symptoms.
My recommendation is Raybestos from your friendly parts store.
You can waste your money ($60 each) on slotted/drilled if you really want,
or get flat ones (PG Plus) for about $30 each.
I shouldn't say waste your money, as the slotted ones WILL look good.
Old Jun 15, 2006 | 05:48 PM
JoeRags's Avatar
JoeRags
well, symptoms are: pedal to the floor, and very weak. The car will stop, but takes a good distance.
inspect rotors... uneven wear, looks like no contact in middle of rotor
Checked for leaks... none
opened up the MC... 3/4 full
checked rotor thickness.... from what I'm hearing, they are too thin
the MC was replaced when we did the frame off, so its new.
What would cause air to get in the lines after driving? I guess it could use a bleed, but I wont be happy until I know why.
If I've got weak vacuum to the booster, could that cause the pedal to the floor problem? I would think it would be a hard pedal in this case.
thanks...
Old Jun 15, 2006 | 05:58 PM
GTR1999's Avatar
GTR1999
Joe,
If you have rotor runout and bearing endplay you'll have brake problems and will get air pumped into the system. Did you check the runout when you installed the brakes and were the bearings worked on?
Call me and I'll go over the job with you.
Gary
Old Jun 15, 2006 | 06:39 PM
JoeRags's Avatar
JoeRags
any good mail order suppliers for rotors and pads?
To rotor thickness?
