What do you do about spider cracks in the fiber glass? I am stripping one down now and have spider cracks in several areas do you have to fill them with something? I am going down to the original primer in these areas.
mine went right into the seal coat on the glass. i was able to use filler on them at that point but in most places I sanded them out and then primed with an polyester primer to replace the seal coat.
Thanks I was not sure if I had to fill them or if they would show up in the paint
When I repainted mine...I took off the nose, bumpers and all...painted, looked great, no spiders...but after putting it back on the the slightly different config, etc...they came back
