what are these?
Old Jun 15, 2006 | 07:19 PM
SizzleChest's Avatar
SizzleChest
Default what are these?
i've been trying to find the cause of my electrical short that keeps killing my stop light fuses. http://forums.corvetteforum.com/show....php?t=1414544
just curious what the black box is next to the fuse panel in the first pic and also what the white relay shaped thing is. (if it is a relay, what circuit is it on? it only has 3 terminals - i've only ever seen 4 and 5 post relays)
Thanks!
http://members.shaw.ca/sizzlechest/111-1151_IMG.JPG
http://members.shaw.ca/sizzlechest/111-1152_IMG.JPG
Old Jun 15, 2006 | 08:12 PM
sdonnelly's Avatar
sdonnelly
I believe the black one is the voice data recorder. Not sure about the other one.
ttt
Old Jun 16, 2006 | 09:10 PM
SizzleChest
Old Jun 16, 2006 | 11:01 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Well, the black thing is the buzzer for all your buzzing needs. Seatbelts,ignition key. Not sure what the white thing is for, tho.
edit. OK, this is a guess. Is there a tan and red wire to the white thing? Headlight warning buzzer.
Mike
Old Jun 16, 2006 | 11:08 PM
...Roger...'s Avatar
...Roger...
the black box is the ignition key buzzer---this is what I told you to unplug to see if your short went away.remove conn. with pink and orange wires
Old Jun 16, 2006 | 11:12 PM
big_G's Avatar
big_G
White one is probably the horn relay
Old Jun 16, 2006 | 11:14 PM
...Roger...
Old Jun 16, 2006 | 11:58 PM
...Roger...
If you have cruise the brake light switch is also a cruise disconnect unplug cruise portion plug and try.It is also hot with key on.
Old Jun 17, 2006 | 12:07 AM
...Roger...
If none of this works disconnect the turn signal switch conn. the flat one with around 10 wires and see if short stops if it does that will isolate a few things.
Old Jun 17, 2006 | 08:15 AM
theandies's Avatar
theandies
Since each year of Corvettes are just a little bit different it would be nice to include the year of your car in the post just to be a bit more clear and get better advise. I have a '71 and don't have either of those boxes that I know of.......at least not in that location.
Old Jun 17, 2006 | 08:30 AM
SIXFOOTER's Avatar
SIXFOOTER
the horn relay is a large one under the hood I believe
Old Jun 17, 2006 | 09:15 AM
...Roger...
Sixfooter thats on the older ones your 81 and his 78 are on the inside.
Old Jun 17, 2006 | 06:14 PM
SizzleChest
no cruise control on my 78
Old Jun 17, 2006 | 06:15 PM
Twin_Turbo's Avatar
Twin_Turbo
white = horn relay
box = key buzzer and seat belt warning light timer
To what are these?
