Epoxy or Polyseter resin for '76 work
Old Jun 16, 2006 | 03:51 PM
Scott Marzahl's Avatar
Scott Marzahl
Default Epoxy or Polyseter resin for '76 work
A quick C3 bodywork question. I've just finished work on a C2 and I am of the understanding that at least some later years of C3s need to use Epoxy products. When doing body work on the '76, should I use Epoxy or Polyester resin with the fiberglass mat? If epoxy, what kind does everyone use? I believe Evercoat 870 filler is still fine to use on this year.
Old Jun 16, 2006 | 04:10 PM
TheMongoose's Avatar
TheMongoose
i used a polyester primer because i went down to the fiberglass in a number of spots. I also have a 76 and they hadn't gone to the smc panels yet. i used the evercoat body filler on everything after that. once i got the rippples out I went to a glaze and then an icing both from pro-spray prior to seal coating and painting
