My hoods stuck!
Old Jun 19, 2006 | 03:00 AM
Enersis's Avatar
Enersis
Default My hoods stuck!
Only one side pops open, i cant figure out how to get it too pop.
Old Jun 19, 2006 | 08:59 AM
skydaddy's Avatar
skydaddy
http://www.madvet.com/shop?store=1&...=236&frame=3852
this will help.
Also you might want to try searching the archives. There are plenty of threads just like this one and they also include the stuff guys have done to keep it from happening again.
When mine stuck (the plastic on the cable actually slipped (brand new cable too), I made a tool (an old screw driver) bent like a banana to get in there really easy.
Takes some practice finding that tab though.
Old Jun 19, 2006 | 05:16 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
It's a bit tricky but once you do it you will go "Wow". Pop the plug out wiper arm area. Stick your middle finger in the hole (no jokes) and feel the latch to get an idea of what your are aiming for. Take a medium size screwdriver and place the blade against the latch you just felt and push forward. It will pop and the hodd releases. It may take a few tries. I advise anyone who has never done it to do it before you have to.
Old Jun 19, 2006 | 11:12 PM
Enersis's Avatar
Enersis
thank you.
what happoned is the clip that holds the wire in place snapped, so i have to buy a new wire
Old Jun 19, 2006 | 11:26 PM
Scottys78's Avatar
Scottys78
My driver side sticks but after a few bangs it usually pops. Waiting for it to actually fail
Old Jun 20, 2006 | 02:09 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
this will help.
Works like a charm, it happend to me once. After you get it open adjust the cable so you don't have the problem again.
Old Jun 20, 2006 | 07:38 AM
TSAGG's Avatar
TSAGG
if one side pops up and the other is stuck, give the side that is popped up a slight push on the side, pushing it towards the stuck side. the stuck side should pop right up.
Old Jun 20, 2006 | 08:38 AM
skydaddy's Avatar
skydaddy
glad it worked for you.
Now that you have the hood open, practice with the hood open. It will happen again one day and it is good to familiarize yourself with what you have to do.
Like I said in my 1st post, I actually bent a screw driver to help out with this chore when it happens in the future.
To My hoods stuck!
