Windshield Wiper Help Needed
Old Jun 20, 2006 | 01:44 AM
Mpls Funk's Avatar
Mpls Funk
Default Windshield Wiper Help Needed
Hi,
I have a 1970, small block. I am having trouble with the windshield wipers. When I go to turn them on, the wiper door opens up (most of the time...I think I have a small vacuum issue also, but that's a different story), but the wipers never go.
I'm not sure if there is a fuse in the electrical circuit...or if the motor is just shot, etc. Any advice on where to start looking for these parts and how to trouble-shoot.
Getting behind the dash really intimidates me...I'm afraid I'll never get it apart without breaking something, and if I do...I'll never get it back together to look tight and nice and neat (and work properly again).
Thanks!
Old Jun 20, 2006 | 06:45 AM
Skunkvette's Avatar
Skunkvette
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I don't know if this will help, but I had a similar problem with my 72 right after I bought it.
Check the "park" **** under the dash. It is the round **** between the two override pull switches.
Someone had parked my wipers in the down position, so my wiper door would open but the wipers would not move. Simply turning the **** put me back in business, I hope it is that easy for you....
Old Jun 20, 2006 | 07:14 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Wait before you monkey with the dash stuff!!! spray some silicone spray lube into the wiper motor...when was the last time you used your wipers? the motor may be stuck..it can happen. hope this works out for ya just did the same thing on a 72 works fine.
Old Jun 20, 2006 | 10:33 AM
Mpls Funk's Avatar
Mpls Funk
Thanks for the notes guys...
What is the purpose of this "park" *** under the dash? Why would someone want to turn that? I will try that tomorrow.
I haven't used my wipers in a couple years (because of this problem). I hate to sound stupid...but where do I look to find the wiper motor to try spraying that lubricant you mention?
Old Jun 20, 2006 | 10:36 AM
theandies's Avatar
theandies
It is so you can change the wiper blades.
Also check that the wiper door open switch is being made. It is located on the firewall next to the wiper door vacuum actuator. This supplies power to the motor after the door is completly open. Also make sure your wiper motor and the wiper switch on the dash both have good grounds.
To Windshield Wiper Help Needed
