A/c Condensor Overheating !!!!!
Old Jun 23, 2006 | 05:45 PM
WRAITH666's Avatar
WRAITH666
Default A/c Condensor Overheating !!!!!
HELP HELP HELP !!!!!!!!!!!
I have a ' 76 that I dropped a '94 lt-1 into . My problem is the condensor " overheats ", and cuts off the a/c . I have 2 electric fans that DO NOT go through the computer, but rather , are connected to 2 relays .
One idea I had was to connect one fan through a relay that would be connected to the a/c harness. When the a/c is used, that fan would come on . As the engine heats, the second fan would come on and cool the radiator along with the first . When the a/c is off, both fans would work as normal to cool the radiator .
I hope someone has a better idea than this one . It's the only thing I could think of . .
Old Jun 24, 2006 | 01:50 PM
noonie's Avatar
noonie
Don't be afraid to have both fans come on with the a/c circuit. If it's hot enough to use a/c, then it certainly won't hurt your engine coolant temp. Almost all modern cars are setup this way.
The more you cool your condenser the better your a/c will work.
Always use guages to diagnose a/c problems. You may just be building too much pressure.
Old Jun 24, 2006 | 02:33 PM
WRAITH666's Avatar
WRAITH666
Ok then , if you think it's a pressure problem, what would . or should, the proper pressure be ? These are 2 different year a/c parts from different years .
Old Jun 24, 2006 | 02:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Search the C3 Tech forum, there have been several recent discussions on A/C modifcations.
Old Jun 24, 2006 | 05:48 PM
palazzopl's Avatar
palazzopl
on a 80 degree day the low side should be about 30psi and the high slde about 250-275 if the low side is lower it might need freon, if the high side is much higher you might have a blockage ( junk in the orifice)these numbers are for R12 freon
Old Jun 24, 2006 | 06:14 PM
WRAITH666's Avatar
WRAITH666
The compressor is a ' 94, so, it's using the R-134 .Someone who did this conversion told me to run the system at 20% less than the stock R 12 capacity . Sound right to you ?
I know DeWitts has special relays to work the fans with a/c, but, to rewire everything is a bloody nightmare. But, if that's what it takes, so be it.
Old Jun 24, 2006 | 09:05 PM
noonie's Avatar
noonie
It Could be a pressure problem.
The pressures are all relative to the ambient temperature. Here in 95* weather, I run 35psi low side and 235 psi high side and get 38* vent temp.
Both the evaporator and the condsenser have good air flow and clean inside.
If you have internal blockages and/or poor air flow you will get excessive psi and the high limit will kick off the compressor. It may be as simple as a blend door stuck. I have never heard of a "condenser overheating" but I am assuming this is what you mean.
I am taking this from memory so my figures may be a little off. Without a auxillary condenser fan the high side was 260psi, then turning on a 2400cfm spal pusher fan the high side dropped to 220psi.
Basically, without getting technical, that is a very good result and aids in better cooling and longer compressor life.
When you wire the fan for the a/c don't tag the compressor clutch feed or the fan will cycle with the compressor. Tag the a/c on from the dash control itself.
Unless you have an obvious problem such as a broken wire etc., you must take your temp and pressure readings and diagnose from there, otherwise you're just shooting blanks.
Old Jun 25, 2006 | 04:50 PM
WRAITH666's Avatar
WRAITH666
I contacted DeWitts and got the following as a fix to the problem . They said to get another relay, and connect it to my existing fan relays . Connect one wire from the new relay to the sending unit of the fans, and then connect another wire to the + 12 volt wire of the a/c clutch ( the colors are listed in the instructions ) . The fans will kick on when the a/c is used. Sounds a bit complicated , but it really isn't. Just a pain to rewire everything !! Again
Old Jun 25, 2006 | 10:12 PM
noonie's Avatar
noonie
You really don't want your cooling fan(s) kicking in and out with the compressor clutch cycling. It's hard on the fans, relays, fan motors, alternator and a/c system pressures. When you turn on the a/c, you want the fan to stay on until you turn off the a/c.
And besides, it is also just annoying.
Just use bosch type relays. They are industry standard.
They all wire the same.
http://www.mcminone.com/product.asp?...duct_id=26-534
To A/c Condensor Overheating !!!!!
