need more help
Old Jun 23, 2006 | 11:06 PM
jag2241's Avatar
jag2241
Default need more help
for some odd reason my 79 vette dosen't start after i had just driven it, what could cause this, could it be the starter or the distriburator getting hot. anyone know what causes this? pleas and thanks for any help
Old Jun 23, 2006 | 11:13 PM
Greg's Avatar
Greg
Just another Corvette guy
Joe,
What do you mean by "doesn't start"? Does it crank over but not flash? Or do you turn the key and get nothing?
Greg
Old Jun 23, 2006 | 11:14 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Have Starter checked...
Old Jun 23, 2006 | 11:44 PM
DMONSVETTE's Avatar
DMONSVETTE
Or just buy a new one.
Old Jun 24, 2006 | 12:04 AM
jag2241's Avatar
jag2241
it doesn't turn over, nothing happens, it shows that there is power, my dad said that it could be the distriburator
Old Jun 24, 2006 | 12:07 AM
jag2241's Avatar
jag2241
i wonder how much a high performance starter and distriburator would cost maybe that would solve my starting problems, also like to say thanks for the help and sorry if i don't spell distriburator right
Old Jun 24, 2006 | 12:18 AM
Greg's Avatar
Greg
It's not your distributor. If the car will re-start after it's cooled down, you're going to need a new starter.
Good luck,
Greg
Old Jun 24, 2006 | 12:24 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Try disconnecting and reconnecting the battery cables at the battery. Tight. Solved my similar problem in my white 79.
Old Jun 24, 2006 | 12:59 AM
BLUSHRK's Avatar
BLUSHRK
If this happens after you've driven it, then it's MOST LIKELY because the solenoid on the starter is too hot. I tried everything from wraps to shields and nothing worked. Replaced with a "mini-starter" and a wrap and she starts every time.
Old Jun 24, 2006 | 01:13 AM
jag2241's Avatar
jag2241
thanks for the help , i will try out the advice you have given me
To need more help
