I'm sure this is a common Corvette issue. My driver's headlamp tends to "wink" under throttle. I figure it's probably a vacuum problem, but how do I go about correcting it?
There is a vacuum check valve in the line coming from the manifold to the resevoir tank. Sounds like yours is bad so the vacuum in the tank follows the manifold vacuum. Cheap fix.
Okay, I read the troubleshooting guide and the first steps I took was to replace both the check valve and filter from the manifold. This didn't fix the problem Without hooking up the vacuum pump to all the components I'm thinking a bad actuator relay valve?? It only affects the driver's headlamp, and only under heavy throttle (i.e., going up hills). Also I now realize my headlamps do not go up like they should when the car isn't running.
I have the same problem as you, exactly. It's even on the driver side. The problem existed before the motor swap and I just never got around to fixing it. Read as too many other problems. Anyway, I believe I've tracked it down to the actuator relay valve. I bought a replacement and will install it this weekend assuming I can contortion myself to getting to the screws holding it in place. Does not look like fun. I'll let you know how it turns out.
Just to reiterate: I have installed a new check valve. I made sure it was installed just like the old one was removed (the old one was original, so I don't think that was installed the wrong way).
I will check all the headlamp springs, just to rule that out.
Razorhorn, keep me updated! I'm thinking a leaky actuator valve,based on the fact that it only affects one side and the reservoir doesn't seem to be holding vacuum.
I graduated from University Park in '98. Used to live across from Pennsylvania Pizza on College Avenue (geez I can't even remember the name of the apartment complex anymore).
Well, I did get around to replacing the relay valve with a new replacement. Now I have a monster vacuum leak somewhere and the idle is very rough. It's somewhere in the assembly I just dinked with. Other priorities usurped me fixing it this weekend. I'll keep you posted how it turns out.
