Looking at a 73 project car that does not have power steering. The problem is the car does not run so I can't drive it. How big a difference does not having power steering make?
I've run manual steering on my '69 for over 30 years. For most of them, I ran the Power Steering ration (2.7 turns lock to lock). I switched back to the standard manual ratio (3.2 turns lock to lock) with standard castor specs. I currently run 245ZR45-17's but have run 255ZR40-17's, 215VR70-15's,and 225R70-15's so I have fairly wide and very sticky tires that make the manual steering harder. I also ran the PS spec for caster making the steering harder but adding straight line stability until this latest adjustment. At anything except parking speeds manual steering is great.
I am 50 now and may put PS on my car this winter. If the PS is right it really isn't too bad from a feel standpoint if the pump is set at the right pressure (higher than typical GM PS) and the valve centering springs are right, my fear is that MANY (stock) setups have a lot of lost motion in the steering that makes the steering feel less direct.
My '69 was my flagship car from Feb 12,1976 until Jun 6, 2005 and I wanted all of the power going to the drive wheels. Now, with my (then) new Viper SRT-10 convertible as my reining flagship car and solidly the most seriously fast car, the few added pounds of PS do not concern me and will make my '69 more pleasurable to drive.
StickShiftCorvette,
Going to a power steering pump with more pressure relief than stock is not a good idea. The stock pump has a relief setting of (900/1000 psi) for all C3 model years. Increasing the pressure will not affect steering feel. The special Corvette small diameter (1/4 inch inside diameter) power steering hoses were only validated to 1000 psi. The don't like pressures above that.
As long as you can steer full lock to full lock with the car stopped, engine running, and the foot brake applied; you have sufficient pump pressure. Any more pressure will only cause more stress on the hoses, seals, etc.
The C3 Vettes had different flow rates through the years. For the life of me, I don't know why. (1981-82 pump changes were for improved fuel economy).
1968-69 had 1.75 gallons/minute flow
1970-73 had 1.6 gallons/minute
1974-80 had 2.9 gallons/minute
1981 was a smaller displacement pump with 2.9 gallons/minute
1982 was that same small displacement pump with 1.9 gallons/minute
The actual power steering system didn't change. However, tires changed greatly through the years. You may want more flow, but not more pressure.
[QUOTE=Jim Shea]StickShiftCorvette,
I didn't say I would want a higher than normal CORVETTE pump setting. I could be mistaken, but I think Corvettes CAME with a higher pump setting than other Chevys with integral steering box power steering.
The lower the pressure is the more lost motion in the steering valve will be felt in the steering wheel. On Corvettes set up right it is NOT a problem, but I have seen many PS Corvettes with unreasonably sloppy steering - I am guessing it is sometimes due to using a standard Chevy PS pump instead of a pump set a Corvette pressures.
I GUESSED WRONG!
I just checked the manual and Corvettes have LOWER pressure pumps than most Chevy's so, as the saying goes: "NEVER MIND!"
You really do get use to not having power steering. You just learn to crank the wheel with both arms when parking. I don't think it's a big deal at all.
According to the "Corvette Black Book" 27,872 of the 30,464 73s that were built had power steering, where as my 68 only 12,364 of the 28,566 built had power steering. My doesn't have it, neither does my 72 Datsun 240Z (which was my daily commuter for ten years). Parking is the only time I notice it, well only when I'm parking slowly
If you were going to have a C3 for an autocross or road track car, which would be preferable? Would it matter?
Converted the P/S for my 73 to manual; which for me is preferred for racing, road included. Don't like P/S on performance cars, also thought the original P/S system sucked. Whatever works for you.
This is interesting. Let me ask this, if you were going to have a C3 for an autocross or road track car, which would be preferable? Would it matter?
The steering in Vettes is always technically referred to as "power assisted," and, in my opinion, it's not as "fast" as I'd like it to be. If I were setting up for autocross, I'd want it to be faster. I've never driven a manual steering Vette so I don't know if they can be steered more rapidly.
I think I am eventually going to change to the high speed power steering box that is commonly used on Jeeps. The are much quicker. Do a search in C3s for the Jeep power steering box...
I had a 1991 Toyota truck about 10 years ago that came without power steering and a large diameter plastic rimmed steering wheel......it sucked trying to make sharp low speed turns about broke my back with that truck....that was my only dislike about it.
Can't imagine this same scenerio trying to manuver car ith a long front end (corvette) around the same way
I have manual and am actually thinking of going power. I would not use the stock setup, but the jeep box (corvettesteering.com) seems to be the way I would go.
I think I have a power steering leek from a hose under the right front of the car but I can’t tell if its ATF coming from the tranny cooling line that goes to the radiator
Although I've seen ppl add power steering stop leak made by LUCAS...The color of the oil is the same as ATF,making it more difficult to ditermine what oil it is.....But usually the power steering will leak from the left side of the car..rarely on the left side...you have the tranny cooling lines there
I had to replace some on mine last week...got pin hole in one of the lines
My 72 does not have power steering. When I first bought the car I thought that I wanted to add power steering. The car was set up using the power steering ratio holes. I had it changed back to the manual ratio holes and that made steering at slow speeds a tad bit easier. Now that I've been able to drive the car a lot more I've gotten used to the feel. I'm used to driving it and it doesn't bother me anymore. It actually like the feel now. I even changed over to performance tires (255/50/17 Fuzion ZRi's) and that really didn't change the steering effort much, if at all. Like others have said at real slow speeds like pulling into a parking spot you'll probably have to use both hands. Other than than it drives just fine. I wouldn't be put off from buying a car that doesn't have power steering. You can always buy a power steering kit and add it if you really don't like how the car drives.
