Can someone tell me what this valves name is? Been trying to get one and it seems the parts stores can't get it or a steel fuel line from the pump to rochester carb.....maybe I'm describing it wrong or is it a dealer idem only....thanks
it looks like a filter to me. it might just be an inline filter for the brake booster. the piece that plugs into the brake booster itself is the check valve or pcv valve..... whatever you want to call it. you probobly already know but just incase you or someone else doesnt know the valve that is pluged into the brake booster is a oneway valve that will allow air to flow one direction which is out of the brake booster and then closes if air tries to flow back into the booster that way the booster can hold a vacume.
Do you have a problem with booster vacuum assist ? I ask as I have a real hard brake pedal now,an suspect either that "filter/valve" line or the brake booster itself...(78 Sa)..
No not that I'm aware of...just lost the part in the shuffle.
Monday I'm checking with a local vette shop..know he sells boosters..but think that hose/filter rig comes with them..I'll see if he has any separate from booster...
Rich
Not trying to hi-jack the thread, but where should the other end of the hose plug into on an aftermarket carb? I had an edelbrock and now a holley that neither had the hookup for the engine end of that hose.
What does it do? Hook into the vaccum system to provide vacuum assist to the brakes?
Can it plug into the same manifold port as the headlights/canister/transmission?
It is vacuum assist..I would think you could just hook it up to another source...??
Rich
Thanks ...but I finally found one at a parts store .....took awhile though......
Was cleaning up the engine bay ...took parts out put headers on painted allot of stuff...just now putting it all back and it disappeared...gremlin or something
