Burning oil- Temporary solution?
Old Jul 15, 2006 | 07:11 PM
CoolShark's Avatar
CoolShark
Default Burning oil- Temporary solution?
I have and 67 Chevy (not Vette) convertable that is burning oil. I don't want to mess with the engine until I get my 72 LT-1 on the road. I need a temporary solution. Anyone had experience with FHS SmokeLess oil, Bardol No-Smoke or any other such product? I like to put around in it, but I'm afraid I might get a ticket!
Old Jul 15, 2006 | 07:18 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
You may be able to reduce it by going to a thicker oil. Lets say you are running 30 weight and go to 20 w50 or straight 50 after that it is hard to find the 60 and 70 weight oils but you can find those at your local Harley dealer.
Old Jul 15, 2006 | 07:42 PM
694speed350's Avatar
694speed350
To be truthfull about it i don't think there is a a simple solution to your problem in my opinion for what its worth. if the car is smoking while driving the car it's wear or ring problems. all of the products out there that claim to stop oil burning are a waste of money and time.
Old Jul 15, 2006 | 07:44 PM
SHAKERATTLEROLL
I have to agree as I do not think the snake oils do anything. That is why I mentioned the thicker oils.
This still might be not to bad to fix if it is just valve guide seals.
Old Jul 15, 2006 | 08:51 PM
Greg's Avatar
Greg
Just another Corvette guy
Hey Ron,
Is it an Impala?
Greg
Old Jul 15, 2006 | 08:56 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
2 or 3 cans of STP at 2 bucks each would work. someone here said the smokeless oil did work.
Old Jul 15, 2006 | 09:16 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
It could be leaking by the valve seals - in this case STP might help.
If it's your PCV then there is a good temporary solution (Bubba's finest)
Do you have oil in your air filter ? If so it's coming from the PCV (positive crankcase ventilation) hose.
Remove that hose and install a longer hose, route that to a 2Liter CocaCola bottle that you mount somewhere under the hood.... check how much oil is in that bottle (every 100 miles or so) and pour that oil back in the engine.
Yes this is Bubba..... but it works
Old Jul 15, 2006 | 09:27 PM
comp's Avatar
comp
need more info ??? does it foul plugs ??? could the oil rings be stuck???
Old Jul 15, 2006 | 09:49 PM
Red70vette's Avatar
Red70vette
Buy oil by the case.
Old Jul 15, 2006 | 10:41 PM
windsoreight's Avatar
windsoreight
From my expirence synthetic dosen't smoke.
To Burning oil- Temporary solution?
