cooling question
Old Jul 20, 2006 | 11:23 PM
Bangkok Dean's Avatar
Bangkok Dean
My car has always run cool but with the AC on in stop and go traffic the condenser does not work good so I have added two more fans in front of the Condenser. Now with four fans it still does not condense as it should.But the temps in the city run 100+ most days and traffic is a problem 24/7.
Old Jul 21, 2006 | 12:20 AM
rihwoods's Avatar
rihwoods
Originally Posted by ffas23
Haven't looked at my manual on my 73' in probably 25 years but I never saw it run hotter then 195. Actually just about everything I drive very seldom will goe past 200 unless sitting in traffic on a very hot day.
I think the stock cast iron head 427's the manual was written for might be true about the 210-230 range...the aluminum head 502 in my 69 never see's 210...even in heavy traffic at air temps of 100 F +...and the rad is a four row copper brass,with thermal clutch fan...
Probably important to know engine specs when comparing this data..
Obviously,the aluminum head engines disapate heat more efficiently than the cast iron versions..
