cooling question
Old Jul 19, 2006 | 12:03 AM
Nemesis_152's Avatar
Nemesis_152
Default cooling question
would it be possible and useful to hook up the wiper fluid reservior to a set of misters near the radiator for short-term cooling help (such as climbing hills)? i noticed a large temp increase when cruising up hills over the weekend (i-40 through northern az), and it got me thinking about making a toggle-switched mister setup.
my specific questions involve the pressure put out by the pump, and the effectiveness of the mist if anyone has done this. keep in mind that this is an AZ car, so the mist would likely have a pretty rapid cooling effect on the air.
Old Jul 19, 2006 | 12:30 AM
icanfixitforyou's Avatar
icanfixitforyou
The best cooling mod I made for the money was a high flow water pump (and thermostat) made by Stewart Industries. It was under $100, only took about 1 1/2 hrs. to swap out and I could see an immediate improvement in cooling, plus my washers still work. I'll bet you get some big ole bugs on the windshield in the Az. desert at night!
Old Jul 19, 2006 | 04:54 AM
ffas23's Avatar
ffas23
What year is your C-3. You have no listing in your profile. It might help to list what you drive and what engine is in it whether stock or modified. How hot did the car get? My 73' stays cool in the hottest weather even with the A/C on. Maybe your thermostat is going bad. Maybe your radiator needs a cleaning. There are so many things that could cause your car to over heat but based on what you have told us you didn't tell us much to go by.
I don't think your idea of using the washer pump to try to cool your car down will make a difference. Depending on how hot your car is getting it would probably be cheaper to just add an electric fan to your rad.
Old Jul 19, 2006 | 06:53 AM
PhotoVette1's Avatar
PhotoVette1
I have thought about this too--in terms of assisting the a/c in initial startup from a hot parking lot. My thought would be to have a collection bottle set up to collect the drippings from the evaporator coil. Then, during the first 5 minutes from starting the a/c, it could mist the condenser coil.
As to engine cooling, it would probably be better to mist the intake air to the carburator to reduce combustion temperatures--this is not a new idea-->
http://www.invoauto.co.uk/Products/W..._vapor_jet.htm
Doing it this way allows manifold vacuum to draw the vapor in--no pump.
That said, a Dewitts Aluminum radiator, big fan/water pump are the way to go.
Old Jul 19, 2006 | 10:39 AM
kevinator80's Avatar
kevinator80
Man, I thought some of my ideas were crazy. The mechanicals of our cars have been engineered to perform if set up properly. Its when we make changes or systems need servicing that causes them to not work efficiently. Fix your problem don't add to them.
Old Jul 19, 2006 | 11:03 AM
rihwoods's Avatar
rihwoods
Recently was driving my 78 Vette out in Amboy,Ca for two days....when pulling a gradual grade with A/C on in ambient air at 110 F,coolant temps creeped to 215-220...I shut down A/C and slowed to 60 mph..temps dropped to 205 or so...
I checked on what my clutch fan was calibrated at after returning...found out my thermal clutch comes on around 180 and does not fully engage until underhood temps(air thru rad) reach 210-220...
My old standard clutch fan worked differently..in same conditions,it would not exceed 205 with A/C on...but,I had to keep speed around 60 mph....
Another factor out there ground temps were 151 F.(Raytek readings)..this contributes quite a load on the system as vette just soaks up the heat..
Misting would evaporate quite quickly under such extreme conditions,and don't think it would drastically reduce operating temps..IMO..
Old Jul 19, 2006 | 12:39 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Please tell me you're kidding????????????????
Old Jul 19, 2006 | 01:04 PM
gleninsandiego's Avatar
gleninsandiego
For those of you living back in the humid east, misters are a way of life in the desert southwest. In places like Arizona and Palm Springs in California, there are misters spraying above outside dining areas in restaurants and sidewalks. It is amazing to watch the water evaporate before it hits the ground. And the cooling effect is amazing. The change of phase of water absorbs a lot of energy, and thus heat. Many homes are cooled with what are known as "swamp coolers", which is essentially water evaporating in front of a fan. The key to the cooling is obviously how dry the air is. This only works in a low humidity area.
When it comes to cooling cars, "back in the old days" people driving in the desert would hang fabric or burlap bags filled with water over the front of their radiators. As the water would seep out of the bag and evaporate it would cool the air entering the radiator.
Old Jul 19, 2006 | 01:44 PM
rihwoods's Avatar
rihwoods
They do make such a system for RV's...but..the water tank capacity is around 12 gallons...
I really think an engine oil cooler is a better option...my Trooper had one...no cooling issues in the desert lugging around in that thing...or pulling hills...
Old Jul 19, 2006 | 03:45 PM
kevinator80
There you go. Get you a burlap bag, spray nozzel and a tank trailer to pull behind the vette. Cooling issue solved.
Before I get flamed here, how hot did the car get on the hills? Did it continue to climb or did it cool back down. Or do you just need a project?
Old Jul 19, 2006 | 09:42 PM
Nemesis_152
like i said, this was just something i was thinking of, not something i was seriously considering doing...that's the problem with a 3 hour solo car ride with no stereo
i was just curious if it would work, not trying to engineer the thing
Old Jul 19, 2006 | 09:43 PM
Nemesis_152
the car never gets over about 215, even on hills, but i'm a slow driver (~60mph)...
i've got to be the only 22 year old pilot who drives 15 mph UNDER the speed limit
Old Jul 20, 2006 | 12:45 PM
kevinator80
If it didn't get any hotter that that and it cooled down after the pull I would not worry about it. Enjoy!
Old Jul 20, 2006 | 01:39 PM
kmac73's Avatar
kmac73
My 73 run between 210-220 which is what my owners manual says is normal operating temp. Saw a product called "40 BELOW" at Eckler's has anyone used this?
Old Jul 20, 2006 | 01:43 PM
rihwoods's Avatar
rihwoods
Does your heater work ? Just kidding...
From archives...
http://forums.corvetteforum.com/showthread.php?t=856330
Old Jul 20, 2006 | 07:18 PM
ffas23's Avatar
ffas23
My 73' runs at around 195 degrees or lower. It is not suppose to run any hotter then that. The factory installed thermostat is a 195 degree stat. Don't ever remember seeing that 210-220 was normal in any GM car built back then.
Old Jul 20, 2006 | 07:32 PM
rihwoods's Avatar
rihwoods
My 69 owners manual:
"During normal operation,gauge will indicate around the 210 mark.Hard driving,heavy traffic with stop and go,or prolonged idling in hot weather will produce a gauge reading around 230....."
Goes on to stay shut it down if it gets to 250...and determine cause...
To cooling question
Old Jul 20, 2006 | 08:31 PM
ffas23's Avatar
ffas23
Haven't looked at my manual on my 73' in probably 25 years but I never saw it run hotter then 195. Actually just about everything I drive very seldom will goe past 200 unless sitting in traffic on a very hot day.
Old Jul 20, 2006 | 11:03 PM
icanfixitforyou
My car stays cool in traffic, but sometimes I go over 200* in traffic on a very hot day.
Old Jul 20, 2006 | 11:10 PM
cchristo's Avatar
cchristo
Yes, it would work, I just don't know how well.
It's this kind of thinking that causes advancement, even if the specific idea doesn't quite work out.
