Lower Dash Pads
Old Jul 19, 2006 | 03:35 PM
whitesnake81's Avatar
whitesnake81
Default Lower Dash Pads
How hard is it and what is the best way to change out the lower left and right dash pads? 1973 .
Thanks for your help!!
Old Jul 19, 2006 | 08:12 PM
C3 Stroker's Avatar
C3 Stroker
The right lower pad is an easy screw in replacement.....but if you're also changing the left, be prepared for extra work; you must loosen the steering column and let it drop a few inches....also, you should loosen the upper dash pad to allow room to reach the speedo and tach cables to take them loose.....oh, also remove the center console to allow ample fitting and adjusting room when re-assembling everything.
It's not really a hard job, but it is tedious. While everything is out, this is a good time to replace any other items like dash light bulbs,etc.
It took me about 3 hrs. to replace the upper dash and lower pads on my '69. Good luck.
Old Jul 19, 2006 | 09:20 PM
black77c3vett's Avatar
black77c3vett
man i dred dooin mine but it has to be dun, sooner or later
Old Jul 19, 2006 | 10:55 PM
Garson's Avatar
Garson
I have a set of medium saddle lower pads that are new if you are interested, Non air conditioned car.............
Garson
Old Jul 20, 2006 | 12:46 PM
whitesnake81
THANK YOU FOR YOUR HELP!!!
Old Jul 21, 2006 | 10:15 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
If you are fussy, allow lots of extra time for unforseen items. Be sure you know what needs to be done before and as you are working. Everything needs to go back as you took it out.You may find that you will need to order items you hadn't thought of earlier. Now is the time to do things fight, not after you get it buttoned up. This is NOT a quickie job.
Don't ask me how I know..........
Old Jul 21, 2006 | 12:12 PM
griffths's Avatar
griffths
C3,
How did you route the trip odometer reset cable on your '69? It seems that no matter how I route the cable it ends up kinked and won't reset the odometer.
Whitesnake, sorry for the minor thread hijack but I figured the answer might help you and others as well.
Jay
Old Jul 22, 2006 | 06:06 PM
C3 Stroker's Avatar
C3 Stroker
Originally Posted by griffths
C3,
Jay
I didn't recall any special issues with the trip odom reset cable, but your question prompted me to take a look at it.......and sure enough, mine won't reset either! I never use it, so I never noticed. I couldn't see (or feel) any kinks, but it acts just too tight to reset the numbers when I push the ****. Keep working at it...maybe you'll have better luck than I. (I'm not planning to remove the dash pad to fix it...)
Old Jul 22, 2006 | 11:14 PM
Sayfoo's Avatar
Sayfoo
C3,
Jay
Did mine last week. I think the odometer reset is just a poor design and mostly doesn't work well. The install was relitively easy, took about 2 hours. But, there is a problem. The tach needle bounces around a little now. Seems to be getting better. Only have about 300 miles on it since then. On the 69 vert, probably others also, there is a extra under dash brace that the tach hub/cable rubs against. Pushes the cable connect a little off center? Didn't realize this till I was putting it back together and was hurring to get ready for a big event.
To Lower Dash Pads
