if they are originals, you're gonna want to replace them with ss lined ones anyway, or have them sleeved somewhere, otherwise any rebuild you do has a pretty good chance of leaking again soon. NAPA sells the stock style delco morraine castings with stainless sleeves and new lip seals for a reasonable price if you need to go that route.
As for paint, any autoparts store should have caliper paint that is high temp and supposedly chemical resistant, but the stuff i got from autozone did bubble off wherever brake fluid got on it.
1)Make sure you replace with SS sleeved calipers. I dont thik it is possible to buy non SS sleeved calipers anymore, but you never know.
2)I would suggest the VBP Oring upgrade for safety (no performacne gain but huge safety gains IMHO)
3) Use a 2 part G2 type system. The finish is soo much thicker/nicer than store bought caliper spray apaint. Ive used the Duplicolor caliper spray paint and the G2 system on a friends vette. The G2 stuff put out a much nicer finish - like wet lipstick.
4) If you dont care about #3 above, any enamel paint will do -spray on or brush on. Does not need to be high temp as other forum members will tell you.
If original unsleeved calipers ... may be worth a few bux as cores for SS rebuild.
Most caliper vendors will buy them if so.
I used silver POR15 on mine. Enamel will not hold up to brake fluid. http://nhvette.homeunix.com/ftp/in/brakes/brakes_98.jpg
If you order a set from us, we will powder coat them red, yellow or glossy black for $100.00 a car set. If you email me directly at pattie@vbandp.com, I can email you a pic with the color choices.
It looks sharp if you can see the calipers through the wheels. Don't forget we offer a 10% discount to forum members so I can get you a 10% discount on the brake kit (the powder coating service is discount exempt) and the savings will help offset the powder coating charge.
I painted mine with G2 2-part epoxy, and they turned out great. Before I painted them, I polished all the roughness of the cast iron away, and I removed the cast-in characters with the grinder, and finally filled in the stamped characters. the result are very smooth apearing calipers, and with the lettering, I have fooled more than a few people into thinking they are aftermarket or late model calipers. They are surprised when I tell them they are stock C3 calipers. Here is a pic of mine for some motivation:
Did you buy the calipers stamped? Doing mine and would like to have the Corvette script on the caliper if possible
yours look super!
How do you know what they look like if there is no picture?!?!
This thread is so old that those pics used to be on the forum hosted member's web sites!
Here is a pic. These are stock calipers that I spent hours smoothing, then grinding off any raised cast lettering, and then filling any stampings. The paint was 2-part G2 epoxy. I designed the lettering in Photoshop, and then had a vinyl shop cut them for me.
While these are not Corvette Calipers I hand painted them with 3 coats of the Duplicolor Ceramic paint about 3 years ago on my Miata and they have not chipped or faded from the heat. Brake Cleaner and Brake Fuild will melt into them at first but once fully cured they have held up to solvents. My 1977 still has good brakes on it and the Front were painted with a High Temp Gloss Black the rears were not by a previous owner. When I go to fix the rear parking brake I will clean up the rear calipers and paint them Black also.
Use lots of Brake Cleaner and scrub them down good with a brass wire brush before painting Calipers and let them cure for 24 hours between Coats. No need to hurry if you want a quality finish on them. Hand Paint them so it goes on thicker and do multiple coats is my only susggestions.
