Astro Vent 70 Vert
Old Aug 3, 2006 | 06:14 PM
phclub's Avatar
phclub
New England Events Coordinator
Default Astro Vent 70 Vert
I recently discovered the rear deck vents are operated by vaccum. Can someone tell me where the vaccum line connects to in the front. What is the forward control that operates these vents?
Old Aug 3, 2006 | 06:19 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
The rear Astro Vent door operates from a vacuum source off of the HVAC control wheel. When the heat control is turned to hot, the rear door closes; when the control is on cold, the door opens. At least this is how it operates in a coupe, I am guessing a vert is the same.
Old Aug 3, 2006 | 06:41 PM
theandies's Avatar
theandies
Only closes when the heat control is set to hot.
Old Aug 3, 2006 | 06:44 PM
Bob Onit's Avatar
Bob Onit
I own a 73' and , either the vents are wide open all the time or they have been removed because I see NOTHING when I look inside the vents other than empty space
This is an A/C equipped car...does this make a difference?
Old Aug 3, 2006 | 06:52 PM
7t2vette's Avatar
7t2vette
Actually, I think A/C cars are different, but I can't remember how or for sure. You wouldn't see the door by looking in the grilles from outside anyways, it is only visable from inside the car. What you see from the outside is just the plenum.
Old Aug 3, 2006 | 07:34 PM
griffths's Avatar
griffths
On factory A/C equipped cars the Astro Vent system is non-functional and the vents to the inside of the car were blocked off with plates. I guess it has someting to do with the A/C fan always running on a low setting to circulate air through the cabin.
Regards,
Jay
Old Aug 4, 2006 | 10:34 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I now have my 1st factory NO AC car. I was amazed to find the vent door (vacuum operated) under the rear deck. My other c3s were (are) factory AC cars and I don't recall ever seeing the vent door at the back of the rear storage area. I will check tomorrow to see if it actually CLOSES when I select the temp to "hot". I have never seen it close....but I don't think I have ever LOOKED when the temp controller was moved to "hot".
That's what I like about this forum...I always learn something new.
Old Aug 5, 2006 | 01:28 AM
Z-man's Avatar
Z-man
The vacuum line runs through the center console. Some of it is rubber and some of it is tubing (at least in 1970 convertible). You can see the black rubber line in this photo just behind the shift stalk. It connects to the left wheel mechanism, runs to the right, then back along the passenger side of the console, up over the hump and under the carpet to the rear vents.
Old Aug 5, 2006 | 01:32 AM
Bob Onit's Avatar
Bob Onit
WOW you left out "over the river and through the woods.
Hell of a route
Old Aug 5, 2006 | 01:47 AM
Z-man's Avatar
Z-man
Hell of a route
That's the route to Grandmother's vent...
Old Aug 5, 2006 | 02:16 AM
another-user's Avatar
another-user
quick question about the rear vents. when the car is turned off, what position are those vents supposed to default to?
i guess more importantly, is there any way to lock them into the closed position, with out glueing them shut?
im getting really sick of not being able to keep anything in that rear storage area because it all gets soaked when it rains.
Old Aug 5, 2006 | 02:25 AM
Bob Onit's Avatar
Bob Onit
I believe there are drain tubes that route the water out of the vent area which can fill up with leaves, crud ect:...If theyre clogged then you will have water in the rear of the car
Look underneath where the vents are for rubber tubes and make sure theyre clear
Mine are wide open and I get NO water in the back
Old Aug 5, 2006 | 02:40 AM
Z-man's Avatar
Z-man
Old Aug 5, 2006 | 02:53 AM
another-user
ive flushed both of those suckers out several times now, there very clean. it just seems that every time it rains, with out fail, the carpet is wet back there.
Old Aug 5, 2006 | 03:01 AM
Bob Onit's Avatar
Bob Onit
try a garden hose right down the vent, if it gets wet than the problem is from above.(put some towles down first)
Im sure there are seals/gaskets avail for these vents.
If you drive in the rain and you get water it could be coming from below.... holes or cracks in the pans
*EDIT* center row very bottom.
http://docrebuild.com/dr-r-web/HEAT68-79.PDF
Old Aug 5, 2006 | 03:15 AM
another-user
i think ill probably pick up that rebuild kit. the seals are atleast 20 years old on it right now.
i would drive it in the rain, but there are other problems associated with that. for instance, a dead wiper motor that i havnt gotten around to swaping out yet.
Old Aug 5, 2006 | 03:21 AM
Bob Onit's Avatar
Bob Onit
Call before you order as some of their catalog prices are out of date.
Doc Rebuild has been very good to me
Of course I only live 20 miles from their warehouse so I just call them, they pull the parts and I go and pick them up
To Astro Vent 70 Vert
Old Aug 5, 2006 | 07:26 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
On my vert the rear vents are open as long as the control is on full cold. Turn the dial in the hot direction any and the doors go closed.
Old Aug 5, 2006 | 12:20 PM
fotyfobravo
AMAZING....I just tried it....the damn door closed when the temp is selected to "hot".
Old Aug 5, 2006 | 02:29 PM
Todbo's Avatar
Todbo
the rear vents open on non a/c cars , learned something new
