Well I ordered a new wirng harness the other day from the Last Detail as suggested. It looks just like the original. Thanks for help on finding that one. Now that it has arrived I have decided to wire up some relays for my lights. Can you guys provide me with some pics of where you placed the relays?
Also any other tips and tricks that you may have on this subject are greatly appreciated.
The headlight system operates on vaccum not electric. If you are going to install modified electrical system the wiring harness that you have will be of little use. You are going to have to explain further what you are doing, what year car, and what componants you are modifying.
cutting into the wiring harness right next to the alternator is a handy spot because you can get to all the headlight wiring, and also the alternator and/or horn relay is there for picking up your new feed for the lights; this also puts the relays under the hood out of the elements. I have gotten as far as mounting the relays to the inner fender there, but not wired them up yet.
He intends to put relays at the headlights, with a low
resistance feed. This provides more power at the
bulbs and puts less strain on the headlight and highbeam switches.
Take a look in Speeddirect.com (supporting vendor).
They carry a wiring harness to add the relays in. http://www.speeddirect.com/index.aspx?nodeID=128
It isn't cheap - but the workmanship is impeccable.
Also, it allows you to confidently add the relays without
molesting your original system - AT ALL. It all plugs in.
This is built by a forum member here. He does a great job.
I have one, but have not installed ... until after I finish sanding the body.
What a mess I'm making of my nice new chassis.
Hmmm. Thanks for the link. That is indeed a nice looking setup. I had heard people mention speed direct, but that is the first time I have looked at their stuff.
Ok, thanks for the info. Sounds like we are thinking alike.
To those of you who have already wired up your relays and have had a chance to drive your car after dark, was the difference readily apparent?
Was it like a night and day difference?
The increase in brightness will surprise you especially if you have changed over to Halogen sealed beams, which only output about 80% of their potential with the stock wiring.
I have four relays. One for hi beam, one for low beam, one for the fans, and one for my daytime running/parking lights. Only three mounted now, I need to build another plate to hold all four. I went with H2/H4 100watt bulbs. Makes a huge difference in night time vis.
Use a diagram like this, install the relays on the fenderwell by the alternator.
not my drawing, I "aquired it somewhere" but its the one I am going to use
Thanks for the pictures and the diagrams! That was the kind of stuff I was looking for. The harness with the pre-wired relays looks very nice. I have already ordered a relay kit so I guess I go the "do-it yourself" route.
One question for vettenut though, how critcial is it that the relays be close to the lights? I was planning on mounting the relays to the inner fender near the horn relay bus block, but it sounds as if I need to have them closer to the lights.
Let's assume that the power has to travel 8 feet to the headlights with 20 amps flowing at 12 vdc.
2 feet 8awg buss to the relays drops .052 volts
6 feet 12awg to the lamps drops .392 volts
.444 volt drop
6 feet 8awg buss to relays drops .155 volts
2 feet 12awg to the lamps drops .131 volts
.286 volt drop
In this example, you can see the difference placing the relays close to the lamps.
Ok guys, I started wiring up my relays today. I never have messed with wiring much so forgive my ignorance. When I opened up the harness I noticed that the low beams only had one wire (tan in color) to feed the low beams. That was simple enough. But, it appears that the high beams utilize two light green wires to feed both pairs of lights. Can I simply wire those two light green wires together to feed into and then out of the same relay? My first guess would be yes, but I just wanted to get a second opinion before I wired it up and called it good.
Also, for the ground can I just wire the black ground wire from relay to the black ground wire in the harness or is it best to ground the relays seperately?
I'm redoing all of the wiring in my car. In fact, about 60% of my old cut-out wiring is sitting on the floor next to my bed right now.
"File --> Save with images as" This will surely help me out in the near future when I purchase new wiring harnesses I also like the idea of getting brighter headlights. I've heard about using aircraft landing lights as your highbeam bulbs. I believe 'Ironcross' turned me onto that. The relay idea is another good one. Thank you all for the help.
