help please
Old Aug 8, 2006 | 02:20 PM
chiefgma's Avatar
chiefgma
Default help please
can anyone tell me how to get to the rear wheel bearings and the spindles. can the control arm come off also . have rear end grinding, has to be in there somewhere put on all new u-joints grinding is almost always when i back up in to the driveway do not feel it going forward car drives very smooth. thanks RG
Old Aug 8, 2006 | 03:29 PM
SIXFOOTER's Avatar
SIXFOOTER
Start by changing the rear diff oil, be sure to add in the posi additive, give that a shot.
Old Aug 8, 2006 | 04:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by chiefgma
....grinding is almost always when i back up in to the driveway do not feel it going forward car drives very smooth....
May not be the bearings. Sounds like a spring has broken in the emergency brake and one of the shoes is dragging. You will definitely hear it backing up. Probably won't hear it moving forward.
Ask me how I know?
Old Aug 8, 2006 | 05:03 PM
chiefgma's Avatar
chiefgma
it must have happened to you!!!! i will change oil in rear first thanks for replys this forum rocks and so do vette people
Old Aug 8, 2006 | 10:28 PM
Mark PittPayne's Avatar
Mark PittPayne
I agree that is doesn't sound like a bearing. If you do have to get at the rear bearings I would suggest you get a manual. They all explain the procedure and its a pain in a$$ compared to doing front bearings.
Old Aug 8, 2006 | 10:37 PM
1ARACE's Avatar
1ARACE
Trailing arm comes off yes, if you do remove them, mark how many shims on each side of the trailing arm. And if you have to change bearings or replace e-brake springs, hope your rotors dont have rivots in them major PIA, and will need a drill press to get them out. Hopefully it's a simple fluid change for ya
Old Aug 9, 2006 | 10:17 AM
kevinator80's Avatar
kevinator80
You can check the condition of the wheel bearings by jacking up the car and checking for slack. You could even remove the brake caliper and half shafts and spin the tire to listen to the bearing. Dry grinding sound is not good. If the bearing checks out bad, remove the whole trailing arm and rebuild it. You would be a glutton for punishment if you try to do it on the car and the trailing arm bushings are probably shot too.
Careful, this could lead to a big case of "while I'm at it" cause you are just a few more bolts away from having the rearend out and then you could replace all the bushings etc. in the rear.
Old Aug 9, 2006 | 10:43 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Mark PittPayne
I agree that is doesn't sound like a bearing...
You'd hear a bad bearing all the time, not just in reverse. Been there, done that, too.
Old Aug 9, 2006 | 10:45 AM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
Pull the rotor.
To help please
