'68 Owners: Door lock key??
Any ideas??
I don't know if this is true, but I have read that the lock mechanism itself has a number on it. That number is supposed to be a GM key code. The only catch is , you have to take the the lock mechanism out of the door to be able to see it. A locksmith should be able to make the right key with this code.
Bryan
Bryan
Yeah I have the lock out and I saw that number. I took it to a friend and if anyone can get a key made it will be him. I'll keep you guys posted.
Also, if you want to replace your lock cylinders, do a search in the archives for a post started by "Wesch". About 6 months ago he did a post that described the procedure for converting 69-up locks to 68.
Supposedly there are rings of keys that fit every make/model car that locksmiths have access, but I would imagine that would require them to have a warehouse full of car keys. Much easier just to have the guy match the lock with a new key. Cost me about $7 for a new set, I also got two spare sets just in case.
I am a former locksmith and I can tell you a couple of things about these door locks. If the locks are original to the car, there is a code stamped on the lock casing. A reputable locksmith can either clip or cut you a new key from this code. If the locks are not original to the car, they *may* still have the code. There are many companies that reproduce these locks, most do not have a code on the side of the case. In that situation, again, a reputable locksmith can disassemble the lock and make a key from scratch... I know, I did PLENTY of them. The cost to do this could be upwards of $20.00. If you can have the key cut by using a code, it can be done for under $20.00, in most cases. It sounds like the locksmith you contacted either doesn't have the skills or isn't interested in assisting you. I would never do business with that person. The work is not the complicated or hard. I hope this helps. BTW, I got a '68 too!
Good luck,
Tony
Thanks again
Hope the work. In 38 years, the tumblers could have been changed, and the code on the cylinder won't match the notches in the keys.
Been there, done that.
Chuck
There are many companies that reproduce these locks BTW, I got a '68 too!
Good luck,
Tony
Seriously if you know of any please share
Rick
Corey 68, if you keys work let me know and I might try getting my locks out to get to the cylinder code.
I too have not been able to find 68 door locks so if someone has a link to where they can be purchased I would apprecaite it. I have seen some on Ebay but they usually are missing the key which is what I already got.
Buy the ones on EBAY if/when you find them. Any locksmith can make you a key. They can also change the tumblers inside to make it work with your existing key. Chuck
Start with a key blank. Dip it and coat with a thin layer of candle wax.
gently insert the blank into your lock and turn the blank to push against
the tumblers. Gently remove the blank and observe the marks left in the wax.
From there, you can grind/file the blank to fit the tumbler pattern in the wax.
Has anyone actually EVER done this ? Does it work, or am I spankin' it ?
