Crossfire Guys Please Step On In...
Quick background. Low mileage (<28K) 82 bone stock Corvette. Has shown signs of rough idle lately.
Recently did a tune-up (plugs, fuel filter, O2 sensor, air filter, new gaskets at TBI and air cleaner cover). Day or two after the above was complete she threw me code 45 - running rich.
I've checked tightened every bolt on the intake and TBI assemblies and looked for vacuum leaks - none to be found.
Tonight I notice how dark the base gasket is on the rear TBI. I've ordered a rebuild kit. Think this will solve my problem?
Here is a photo showing the view of the close-ups below.
The bad TBI..me thinks...
The good TBI but I'll rebuild both
Cross-fire engines have a hard time dealing with vacuum leaks of any kind.
It only does this at idle after warm-up...I thought that means the CTS is good to go. Also, she full on stumbles when I pull up on the EGR valve so that means that system is good to go.
The more I think about it the more I think that if that gasket is soaked in fuel then I don't have the same pressure at the nozzle when the car is idling. It may be a small leak - getting worse) so I don't notice it when the car is a speed.
Any other thoughts?
It does look wet though...
Is it possible the problem is higher up in the tower?
You should balance the TBI's when you are done rebuilding. How to link http://corvettefever.com/techarticles/4688/index.html
Jim
