Door Panel Skins
I now have to slice it somewhere to get some glue in there,hopefully i can flatten that area out.
i believe if i have had any earlier experience with this ,i would have done a better job.
) I don't know who was making them for Eckler so I can't comment on whether this is the same provider.
Heat to smooth and adherence are the two tuff parts.
If orginality is for you, go to Al K and get them or send your panels to them and let them install the skins.
Terry
1. Buy the contact cement the vendor suggests. This stuff has to hold well and stay...even when the sun wants to cause it to shrink off the door surface!
2. Plan out the "adventure" extremely well. Determine what areas you will glue down first (usually the recess on top of the armrest since it is the lowest area on the door). [For Pete's sake...DON'T glue the whole door surface at once!!!]
3. Once you start, you can't stop. You can put a "hold" on things while you think about what's next, but you can't go backward.
4. The skin has to be accurately positioned on the door panel at the start. If it is cocked a little bit at the start, it will be cocked a LOT at the end.
5. All surface blemishes (tears, holes, cracks, etc.) have to be repaired smooth before you start. Any flaw will show up in the finished product.
6. If you have hair on your head now...you won't when you get done.
And, finally..... If you still want to try this, you are a man after my own heart. Lots of guts and, hopefully, lots of patience. Get the beer ready for when you need a break.
