radiator is out!
Old Aug 19, 2006 | 10:43 PM
swensonm's Avatar
swensonm
Default radiator is out!
Man you guys are right what a PITA 4 hours in the Tx heat! And now that it is out what do your think....all the A frame bushings are orignal, should I eat the down time and replace bushing and if so Rubber or poly? Now for the Radiator...It was too late to call a shop to have it flow tested and pressure checked and to get an estimate to recore if necessary. THIS IS NOT ABOUT BRANDS! But why do so few seem to just recore instead of replacing?
Mike
Old Aug 19, 2006 | 11:35 PM
big_G's Avatar
big_G
Re-coring is about the same cost as a new radiator and more than some of the inexpensive aluminum radiators.
Old Aug 19, 2006 | 11:37 PM
gonzo14's Avatar
gonzo14
and Dewitts has aluminum (direct fit) rads for around $500 give or take a few bucks. They can be epoxy coated to look completely stock and cool a lot better than the brass/copper counterparts
Gonzo
Old Aug 20, 2006 | 01:07 PM
3rd_Vette's Avatar
3rd_Vette
Mike
In my case, I still have the original in my 1980 but since Im replacing the complete motor this week, I got a killer deal on a lifetime warranty NEW Modine for $170.70 at the local radiator shop. For that price, I wasn't going to bother with a re-core. Since my old orig is still in great shape, I plan to keep it in the box sitting next to the orig motor in the corner of the shop, just in case I ever want it all original again.
Old Aug 20, 2006 | 01:27 PM
BarryK's Avatar
BarryK
fun job removing it isn't it?
now try removing it and reinstalling it......... FOUR times in a week!
yep, had a hard time getting a persisitent leak to stop dripping so each time i put it back in, hooked it up, tested it, and had to pull it again.
And this was AFTER the initial pull and reinstall and I had it taken to a rad shop just to flush clean it and pressure check it for leaks to begin with!
To radiator is out!
