Yet another Replacement Radiator question
Old Aug 30, 2006 | 01:04 PM
Scott Marzahl's Avatar
Scott Marzahl
Default Yet another Replacement Radiator question
I know the best units available are from Tom, however the price is a bit too much for my 17 year old son. His car is a 1976 w/auto and AC. I do not want to spend the time fabing an aftermarket aluminum one to fit either.
That leaves the copper/brass replacements by companies like Ready-Rad and Modine/Proliance. The car always had the correct temp with the stock 4 row, so for his budget we are thinking of staying with the copper/brass ones in the $300 price range. I know Modine has been around for a very long time, does anyone have any comments with regards to quality of the current aftermarket units or is one better than the other.
Thanks,
Scott
Old Aug 30, 2006 | 01:18 PM
SIXFOOTER's Avatar
SIXFOOTER
summit racing has Aluminum rads from Northern for about that. Better deal
Old Aug 30, 2006 | 01:57 PM
Scott Marzahl
Yes they do, but they are not a direct fit and will require some rework to make it fit correctly.
Old Aug 30, 2006 | 02:01 PM
Kalway's Avatar
Kalway
Hotrodsusa.com sells a northern aluminum one that fits right in for $308 shipped. Make sure to use their $15 off shipping coupon on their site when you order. That's what I did, works like a charm.
Old Aug 30, 2006 | 02:23 PM
Scott Marzahl
Thanks, but unfornuately they do not list a 1976 application, up to 1971 and then they skip to 1977 and on, bummer
Old Aug 30, 2006 | 02:34 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
It's really not that much work to get the Summit radiator to fit. That radiator is only $180 or so incl. s/h. Can't beat the price, even if it takes a little effort to get it fit (just my 2c).
Old Aug 30, 2006 | 02:56 PM
Kalway's Avatar
Kalway
Odd, they do skip 73 - 76.
However, looking at the dimensions, a '77's radiator looks like it's almost the same size as a '76s. Perhaps someone could jump in and give us the scoop on the differences between the two.
The 5066 SHOULD theoretically fit, though.
Old Aug 30, 2006 | 03:32 PM
NHvette's Avatar
NHvette
Check for local radiator shops. They should be able to recore your
radiator for much less.
Old Aug 30, 2006 | 03:36 PM
Scott Marzahl
Thanks, that was my first approach. A recore job is $400 locally.
The first thing I notice differently about the '77 and on is the water inlet and outlets are configured differently than the '76 radiator.
Old Aug 30, 2006 | 03:54 PM
Kalway's Avatar
Kalway
If they don't interfere with anything like the fan or a pulley, a simple hose change should fix that problem.
Oh and with the price of new radiators, recore jobs are pretty much worthless.
Old Aug 31, 2006 | 12:46 AM
jackson's Avatar
jackson
That leaves the copper/brass replacements by companies like Ready-Rad and Modine/Proliance.I know Modine has been around for a very long time, does anyone have any comments with regards to quality of the current aftermarket units or is one better than the other.Thanks,Scott
Proliance bought the Modine name ... the Modine you "used" to know is no longer in the aftermarket rad business ... order from em & you'll get an offshore rad ... but there's no real USA OE alternative left that I know of.
Old Aug 31, 2006 | 02:06 PM
Kalway's Avatar
Kalway
All copper/brass rads are sent overseas due to hazardous waste disposal. MOST aluminum rads are built here in the states.
Old Aug 31, 2006 | 02:24 PM
rihwoods's Avatar
rihwoods
Give these guys a call..many options on C/B direct fit...
http://www.usradiator.com/
Also...Dewitts has restoration C/B cores your year in his new catalog...$249..but you would need to get it fit to your tanks...
http://www.dewitts.com/download/2006_2ndEdition.pdf
Rich
Old Aug 31, 2006 | 02:36 PM
rihwoods's Avatar
rihwoods
Huh ?
Old Aug 31, 2006 | 03:03 PM
rihwoods's Avatar
rihwoods
Another source..C/B
http://www.completeradiators.com/sho...lete+Radiators
They have 1976,as well....cheap...
Old Aug 31, 2006 | 03:12 PM
Kalway's Avatar
Kalway
Originally Posted by rihwoods
Huh ?
No company makes OE replacement copper/brass radiators in the states any more due to hazard waste disposal. I called and asked a few companies myself.
Old Aug 31, 2006 | 03:16 PM
Kalway's Avatar
Kalway
If we could get some pics of scott's current radiator I think we could find him a pretty good solution.
Right out of Dewitt's catalog:
"Late 1976 Corvettes used a '77 model with a straight upper neck."
If it's a late model '76 then the northern 5066 will fit fine. If it's an early one he'll just have to adjust his hoses.
To Yet another Replacement Radiator question
Old Aug 31, 2006 | 03:53 PM
rihwoods's Avatar
rihwoods
Well, guess the one in PA and another in AZ are illegal....
http://www.copper.org/applications/a...radiators.html
Old Aug 31, 2006 | 04:33 PM
Kalway's Avatar
Kalway
I don't think those count as OE replacements and will probably cost more than any OE replacement. Also note.
"... Using advanced technologies, including fluxless lead-free brazing, anneal resistant alloys and laser welding..."
Lead-free brazing would eliminate the hazardous waste disposal issue. I'm going to guess they're probably using tin instead, now. The usual c/b radiators are meant to be low cost so they don't want to spend the extra costs on hazardous waste disposal or have to deal with using tin instead of lead.
Old Aug 31, 2006 | 04:39 PM
rihwoods's Avatar
rihwoods
There are "OE" C/B replacements out there...but this link below explains new process...
http://www.copper.org/applications/a...s/no_flux.html
