Wheel question....
Old Sep 2, 2006 | 08:51 AM
JustForFun's Avatar
JustForFun
Default Wheel question....
im wanting to get a set of deeper lipped wheels for my 81. whats the widest, deepest dished/lipped wheel i can run on the 81. i dont mind f tire edge SLIGHTLY sits outside fender lip, but not too much. Deep dish/lip is most important to me. Sizes?? backspacing??
Old Sep 2, 2006 | 09:39 AM
Red73's Avatar
Red73
Do you have the stock rear suspension with stock trailing arms? What size wheel are you looking for? 15", 16", 17", 18", 20", 22"?
Old Sep 2, 2006 | 12:01 PM
JustForFun's Avatar
JustForFun
yes stock with 15 inch wheels
Old Sep 2, 2006 | 03:32 PM
JustForFun's Avatar
JustForFun
Old Sep 2, 2006 | 11:01 PM
wnjlt1's Avatar
wnjlt1
as Red73 had asked, what size (diameter & width) are you thinking about going with? if you go wider, keep in mind you may have to do some modifications such as relocate e-brake bracket, offset trailing arms, custom spring, etc... if they stick out way too far past the fender lip, you may get tire / fender contact issues. there are some members including myself that are running 18x10's / 5.5" bs @ the rear, some with stock trailing arms and others running offset ta's. having a wide lip wheel does look great on c3's
Old Sep 2, 2006 | 11:22 PM
JustForFun's Avatar
JustForFun
so if i run offset TA, the fronts can handle deep dish wheels?
To Wheel question....
