Brought home a 72 sb NOM Bryar blue (now yellow) coupe today. It does have some rust at the windshield pilars but the frame is good, the radiator support is free of rust as well, or surface rust only I should say. Bubba has been playing with one a little, but it's complete, and for the price I couldn't refuse. It was a four speed car but it was changed over to auto??? Why would someone do that? Clutch pedal is still there. No brakes, any help here would be great, I'm gonna start on the brakes first. Oh it does run, trans slips like crazy, but without brakes I didn't try for long to move it. Here's a few pictures..... Hope you guys don't mind a few dumb questions in the future? Let the fun begin! WB
I'm really looking forward to seeing the transformation on this one. Are you going to pull the body?
BTW.......If you want to put it back to a four speed, I bought everything needed to do it and am not going to use it now. Fresh BW t-10, bell housing, fresh clutch assy, flywheel, linkage, shifter, etc.
PM me if you are interested.
Thank you Crazy81, Well I just brought the car home and I'm trying to assess everything thats needed. The frame really appears to be fine so I'm thinking rolling resto? I do know that it's going back to a four speed! If you have a figure in mind let me know,OK WB
ps the dude sure liked yellow, even the stock wheel are painted
PM sent.
So, what color are you going to paint this one. You have already inspired me to paint mine myself, can't wait to follow along with this paint job. Remember, post lots and lots of details!
PM sent.
Probably back to Bryar Blue, I think they only painted 1600 or so this color. It's black inside, so anything works, something blue. Corz Lemans blue looks sweet. If someone could photochop some pics I'd be greatful WB
Some more pic's
Cut and fabricate smaller pieces for the windshield frame or replace the entire thing? Where can I find them? TIA WB
If you can get the replacement parts, I would definitely go that route. It would be a whole lot less work and better in the end. I replaced the windshield frame on my 69 and it wasn't that hard of a job. I got the part's from the dealer, but that was when C4's were in production. I'll check my catalogs and see if I can find them.
The drivers side and the top, don't have much damage, now for the pass. side I can weld in pieces, I'm concerned with alignment after removing the entire frame. One area at a time might be safer no?WB
When I did mine, I measured from the base to the top corner and then across from base to corner. The replacement pieces overlap each other (just like the ones in there now). To remove the old ones, just drill out the spot welds and the come apart pretty easily. When I put the new frames back in, I clamped them in place with Vise grips and adjusted till I got the measurements right on. Then I drilled holes and screwed them together with sheet metal screws. Then I laid the windshield on it to check for fit. After I was satisfied I drilled holes for spot welding. Welded, removed screws, welded those holes, and painted. It worked out well, all the trim fit perfect and I had a brand new windshield frame. You can replace only the pieces you need to using the same technique. bare in mind that I replaced from the bottom pillar piece up. I didn't get into the bird cage. I am quite sure your skills are far better than mine were at that time. I don't think you have a thing to worry about.
